1750
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky q switches off - 15/05
Locked
This message was authored by: Mallio
Everyone who's Sky Q keeps turning off every 20 minutes
My Sky Q kept turning off every 20 minutes.
I tried resetting and had no joy I eventually fix in the settings Setup Preferences by turning the Standby Mode from  Eco to none  and it's been working OK since.
Hopefully this will help you to
This message was authored by: Dubnine
Sky switching of
Go to your settings.
Then system info
Then
Software version set up and
Update, (about 20 minutes)
Then follow instructions
On software version message
This message was authored by: foddrambe
Re: Sky q switches off - 15/05
sky is in for a busy day tmrw
This message was authored by: Mum2005
Sky Q Down
SkyQ down!!!
when will it be fixed ?
This message was authored by: Alfielulu
Re: Will not open
Can open on phone but not on tv
This message was authored by: Raptor606
Top right of page click my settings, then email settings then tick 'do not email me' - click save
This message was authored by: Marcella5
Re: No response
Same here in Rugby, Warwickshire. Sky disconnected to no power. Had no clue, App said no problems in area. Still not back on after mdnight and missed the rest of darts after 10pm.
This message was authored by: AmyLo
I've had the same box keeps going off but it's actually not off the light is on but black screen so I switch it off at the walls and it does it again this hooked a couple of times past few times but it's real bad today and tonight. I to have a sky q box it stay on for about 5 minutes and then goes off and doesn't come back on unless you switch it off and the walls and back on again I can't even log into sky app as it say it's under maintenance to report it getting fed up now
Same in Rugby, Warwickshire. Box froze on but said not connected, tried all sorts to contact Sky and messed with wifi etc. but was defo a Sky problem.
Re: Sky Q goes in loop whilst watching pre recording
It's not a WiFi issue I have virgin media WiFi but sky Q tv so it's definelty an issue with the boxes it self
This message was authored by: TheOne
Definatley something linked to the standby settings on the main Sky Q box.
If you leave the Sky Q on constantly watching something on TV connected to the Sky Q Box (not mini) then it works fine ... the moment you change to a different input (PS4 or whatever), the standby feature kicks in after a while and messes things up OR if you're using Sky mini and leaving the Sky Q untouched then this scenario also messes up the main Sky Q box*.
*Remember Sky Q is the main box here. This needs to work for any of the other mini boxes connected to it to work. The moment Sky Q box messes up, everything goes down.
If you don't want to mess about with system settings, leave the SkyQ viewable on a TV and everything should be fine ... crappy interim solution but works lol.
Re: Sky Q box needs to keep being unplugged
Same here!
This message was authored by: deakmann70
Mine never had the smart standby set (it's always been on active) and I still got the crashes) . Maybe it's fixed now mines been ok since I rebooted about 20 minutes ago (fingers crossed)
This message was authored by: theradioguy
Mine is back and working fine for the last 2 hours. I switched box off, plugged in, turned standby off totally and did the update. All working fine now
This message was authored by: Robbie37
I'm relieved the problem is country-wide and not my box! I just unplugged all my sky equipment and will leave it overnight, hopefully there will be a fix tomorrow 🙂
Locked
Answered - Go to Answer
