Discussion topic: Sky q mini box schedu
Message posted on 22 Sep 2024 03:09 PM
Can I schedule a recording from a sky q mini box to the main box and then watch it on the mini box?
Message posted on 22 Sep 2024 03:49 PM
Re: Sky q mini box schedu
@JN4 yes all boxes can schedule recordings and they can be watched on any box except UHD which can only be watched on the main box
All recordings are stored on the main box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 22 Sep 2024 03:56 PM
@JN4 I am just trying to get my head around your question. So you have a main box and in another room a mini box! What I don't understand is what you mean by scheduling it to your main box!
If you see a program or film you want to record on your mini box just press record and it goes into your 'Recordings' which can then be watched on either box. The only exception being you would have to record it just in HD as last time I checked mini boxes can't take UHD. (If someone else knows if that has changed let us know)
Message posted on 22 Sep 2024 04:05 PM
I am considering upgrading from sky + so was not sure if you could only record from the main box and stream to additional.mini boxes?
Message posted on 22 Sep 2024 04:08 PM
@JN4 In that case as my answer above states, yes what ever you record on one box can be watched on both. I don't think you will regret the switch.
Message posted on 22 Sep 2024 04:19 PM
Can you record directly from a mini box?.As sky told me this was not possible. They said you can only record from the main box and stream the recordings from the main box to any additional.mini boxes.
Message posted on 22 Sep 2024 04:22 PM
You can set programmes to record on a mini box. The recordings are all stored on the main box but can be played on any mini box (except UHD recordings).
Message posted on 22 Sep 2024 04:24 PM
Like @xenon81 says. 👍
Message posted on 22 Sep 2024 04:33 PM
Just checking before I commit to upgrade,as I would want to be able to view different recordings from the main box and the two additional.mini boxes seperately on each of the three.
Message posted on 22 Sep 2024 04:57 PM
@JN4 as we have previously stated all recording except UHD recordings are available to view on all boxes doesn't matter what box the recording was set on, each box can view the same recording or different recordings at the same time with the caveat regarding UHD recordings only being available on the main box
Message posted on 22 Sep 2024 05:03 PM
Sky told me a mini box cannot record as it does not have a hard drive.
Message posted on 22 Sep 2024 05:06 PM - last edited: 22 Sep 2024 05:06 PM
@JN4 correct to a point mini boxes don't have a hard drive but all recordings are saved on the main box but can be accessed by the mini boxes so you can set a recording from the mini box where it is recorded to the main box that has a hard drive then the mini box accesses the hard drive on the main box to pkay back a recording
Message posted on 22 Sep 2024 05:16 PM
How do you access the recording you have made from the mini box to the main box,so that you can watch it on the mini box?
Message posted on 22 Sep 2024 05:24 PM - last edited: 22 Sep 2024 05:30 PM
@JN4 all recording that have been made to the hard drive on the main box are shown in the recordings section that is available on the mini boxes and the main box so you just click on the recording and press play see picture below
Believe me it works I have a main box and 2 mini boxes
Message posted on 22 Sep 2024 05:26 PM - last edited: 22 Sep 2024 05:27 PM
@JN4 wrote:How do you access the recording you have made from the mini box to the main box,so that you can watch it on the mini box?
To watch a recording on the mini box you just open the recordings menu on that box and select whatever you want to watch. All boxes can access all recordings (except UHD).
