Discussion topic: Sky q mini box schedu
Message posted on ‎06 Oct 2024 02:09 PM - last edited: ‎06 Oct 2024 02:12 PM
Re: Sky q mini box schedu
@JN4 wrote:
If I record a programme from a mini box can I then view the recording that I have made from that same mini box?,and also see any other recirdings I have made from the same mini box?
hi @JN4
All recordings are physically made & stored on the main box & there is no differentiation between where it was set to record from.
All recordings can be played on any box with the exception of UHD recordings as the minis can't play UHD content
Also note there is no user profile system to be able to separate recordings
Message posted on ‎06 Oct 2024 02:26 PM
So I can record from a mini box,it is stored on the main box and then the recording can be viewed on the mini box? Just wanted to check as I will be getting two mini boxes of which other people in the house will want to watch and record from their own mini boxes.
Message posted on ‎06 Oct 2024 02:35 PM
Yes
As per my previous reply, however, there is no difference between who or where the recording was set from.
All recordings are available to every box (except UHD) and no way to separate them by who/where requested.
This can be quite a change for customers used to the SKY +/HD multiroom boxes with their own separate recordings
Message posted on ‎06 Oct 2024 02:51 PM
Can I view on a mini box what has been recorded from that box?
Message posted on ‎06 Oct 2024 02:53 PM
Message posted on ‎06 Oct 2024 02:58 PM
Message posted on ‎06 Oct 2024 03:39 PM
@MightyQuinn wrote:
@JN4 wrote:Can I view on a mini box what has been recorded from that box?
Hi @JN4 Yes, the central recordings can be viewed from any box.
I think @JN4 means, unless they really are asking the same question for the 10th time in this thread, can they see a list of just the recordings that were set up from a particular box and the answer is no, it's just one big library of recordings for the whole system.
Message posted on ‎06 Oct 2024 04:38 PM - last edited: ‎06 Oct 2024 04:42 PM
BTW @JN4
If you are awaiting the move from SKY HD to SKY Q there may, also, be some other things you may wish to know in some notes I have made for people considering switching from SKY +/HD to SKY Q
Edit - I just realised I posted this along with others replying when you first asked in September
Message posted on ‎09 Oct 2024 11:44 AM
I had two mini boxes installed yesterday.One of which the signal intermittently drops out.The box is loocated in an upstairs bedroom. Is there a wi-fi extender that might help?. I have BT broadband.
Message posted on ‎09 Oct 2024 11:52 AM
Hi @JN4
Reboot the minis as above.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or previously connected mini).
