Discussion topic: Sky q controller disconnecting
Message posted on ‎23 Aug 2023 09:21 PM
My sky Q controller keeps disconnecting from my tv and I have to go through the set up again.
It then often takes several attempts to resync the controller. It says it is not supported then several attempts later it syncs.
It will then be fine for a few days then goes again.
very frustrating!
Any ideas?
Message posted on ‎23 Aug 2023 09:46 PM
Re: Sky q controller disconnecting
very frustrating!
Any ideas?
Have you tried completly resetting it @NicMeek
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on ‎25 Aug 2023 07:19 AM
Thanks. Yes tried this @oldfella @but still keeps doing it
Message posted on ‎25 Aug 2023 08:43 AM
What TV is it?
Message posted on ‎25 Aug 2023 10:54 PM
@Chodley Samsung
Message posted on ‎26 Aug 2023 02:17 AM
Message posted on ‎28 Sep 2024 11:52 AM
Was there and answer to this ? I have the same issue. Every time I turn the tv off I have to reset the box to get the remote to work again. Samsung again
Message posted on ‎22 Jan 2025 02:03 PM
Hi, did anyone get an answer to this as I have the same issue - Samsung again
