Discussion topic: Sky control
Message posted on 18 Jun 2024 10:17 AM
Sky control
My sky control is not working how can I get a new one
Message posted on 18 Jun 2024 10:22 AM
Re: Sky control
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Message posted on 18 Jun 2024 10:24 AM
Re: Sky control
It is completely dead cant do anything with it
Message posted on 18 Jun 2024 10:25 AM
Re: Sky control
Then use the link I posted for replacement @Lesley196061
Message posted on 18 Jun 2024 10:27 AM
Re: Sky control
Where do i find the link
Message posted on 18 Jun 2024 10:41 AM
Re: Sky control
Same as in my original post @Lesley196061
