Discussion topic: Been having issues with sky. Had to reset the main box with broadband password etc. Now the mini Box
This message was authored by: Stuart75
The on screen suggestions have not worked. This is the second time within a month that the mini box has failed Engineer came lattimer.
Re: Been having issues with sky. Had to reset the main box with broadband password etc. Now the mini
Hi @Stuart75
Reboot the mini as above.
