This discussion topic has been answered Discussion topic: Sky Q on ethernet cable
Message posted on 06 May 2026 12:15 PM
If I have Sky Q on an ethernet cable with WiFi disabled and an infrared remote will I still be able to access Netflix, Amazon Prime, Disney, etc?
Message posted on 06 May 2026 12:17 PM
If your Sky Q box has a working internet connection via the ethernet cable then you will be able to access those apps.
Message posted on 06 May 2026 12:08 PM
Switching WiFi off Sky Q box
We have a son with electromagnetic hypersensitivity so we can't have WiFi in the home. We want to have Sky Q and have been told we can disable the WiFi on the box and have an accessibility remote that uses infrared. We will receive our sky through an ethernet cable which we do now with our present sky box. Would be better able to access Netflix, Disney, Amazon Prime, etc if we have ethernet connection?
Message posted on 06 May 2026 12:26 PM
Re: Sky Q on ethernet cable
If our Sky Q is working on an ethernet cable with the WiFi disabled on the box and WiFi disabled on the TV can we still access Netflix, etc?
Message posted on 06 May 2026 12:43 PM
Re: Switching WiFi off Sky Q box
@TB1555 wrote:We have a son with electromagnetic hypersensitivity so we can't have WiFi in the home. We want to have Sky Q and have been told we can disable the WiFi on the box and have an accessibility remote that uses infrared. We will receive our sky through an ethernet cable which we do now with our present sky box. Would be better able to access Netflix, Disney, Amazon Prime, etc if we have ethernet connection?
Its only Netflix Disney, Amazon Prime that you have from the Internet, and if you Sky box connected to your hub via Ethernet cable there should be no problem accessing them. The rest of your Sky service came from satellite via the dish on the outside of your property.
Message posted on 06 May 2026 08:11 PM
If your box has an internet connection it can access content available via the internet. It doesn't matter how that connection is being provided.
In any case an ethernet connection is aways going to be better than a wireless one.
