75
This discussion topic has been answered Discussion topic: Sky Q. Mini Box Youtube
Re: Sky Q. Mini Box Youtube
Looking like a number of you are having similar login issues with YouTube on one or more of your Sky Q boxes.
Please read this thread and try some of the things already suggested,  if you have not already,  like Sky box restarts and refreshing apps.
It may help some of you.
I have reported the issue in our Superuser closed forum area to make Sky aware of the issue.
This message was authored by: legoman2608
I've restarted my Q box, and it's made no difference. I cannot access YT settings (clicking on the icon doesn't do anything) so I can't refresh the app
Refresh of apps performed on Sky box settings
  1. Press Home on your Sky Q remote, then highlight Settings
  2. Press 0,0,1 and Select to access the Installer menu
  3. Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing.
The refresh can take up to 24 hours to complete.
Ok I'll try that a bit later, ta
I've tried this but don't get an Installer menu. From Settings impressed 0,0,1 but nothing happens. If I press the round button on the remote I get a warning to only proceed if told to do so by Sky, but it's a screen that has LNB and something else, but nothing entitled installer menu
This message was authored by: jsnbts
YouTube app issues
Since yesterday, the YouTube app on. my Sky Stream puck has logged me out of my account, and won't allow me to log back into it.
After completing the sign-in steps, I get a screen that says 'Something went wrong - sign-in failed'.
I have reset the puck and tried the app refresh too, nothing seems to be working. Is anyone else experiencing the same?
This message was authored by: Kris+G23
Re: Youtube App no longer working (Sky Glass)
i have the exact same issue, no matter how many restarts or unplugs i do, the app will not work correctly.
i can cast to it, but it will not let me sign in nor will it show more than 5 random video options.
has sky glass had a recent software update?
Don't know what else to do with it.
This message was authored by: OCALA3
Tried everything listed above nothing. Gave the add account a go but just says 'something went wrong' .
Annoyed now as this should not be happening.
@Kris+G23 Have you tried refreshing your Apps via the Settings menu? Might be worth a try.
This message was authored by: Nimbob Answer
Hey Everyone.
Thank's for bringing this to our attention.
I've escalated the problem to the relevant team here at Sky and can confirm that they are working to resolve the issue.
I fully understand how frustrating this will be and appreciate your patience while this is resolved.
Thanks.
Thanks,
Scott
Community Moderator
Hi, thanks for the advice, unfortunately no joy.
hoping Sky send out a patch for a fix.
thanks again
This message was authored by: TinaW113
Thanks Scott.
One of my mini boxes reconnected after refreshing the app. The other simply won't allow login.
Will an update on the issue and resolution be posted on here or do we have to report it to Sky ourselves to be notified?
It doesn't seem to be a general fault - it's working normally for me too. I'd suggest giving Sky a call to report it.
This message was authored by: Mistry109
Hi guys.
I have the same issue.  I can login fine on the main SkyQ box, but the mini box will not let me log in at all on my profile.  I tried to sign in several times since yesterday. Rebooted both boxes.
Main box is still fine.
Mini box - "Something went wrong".
This message was authored by: grasstrimmer
My YouTube app on Sky Q won’t let me login
It started off with missing the options on the left side of the screen.
Following research, I:
Used the hidden code on "settings" and 'refreshed apps' - no change
Rrepeated 'refresh apps' and turned off sky Q, unplugged box for 5 mins.  Rebooted.  No change.
i then noticed that I had been logged out of YouTube so I've tried logging back in using my google id.
attempt 1 using code on screen and safari and on my iPad - won't work.
attempt 2 ditto (because I couldn't believe it hadn't worked) - no good
attempt 3 logged in manually on tv screen using gmail account and password, then it wanted me to sign in using my web browser to confirm it was me, I did this and I logged in fine on my iPad but the tv made no difference!  Got a screen saying "sign in failed try again".
(the YouTube app is working perfectly on my mini Q box upstairs) .
if anyone has any ideas I'll be grateful.
Answered - Go to Answer
