Discussion topic: Box overheating
This message was authored by: Sb71
Box overheating
Box overheating
being switched off at mains each night due to concern over fire risk
can you please advise
thank you
Re: Box overheating
@Sb71
Is it in a well ventilated position? They are designed to get warm but you should be able to rest the palm of your hand down on the top. If you can't then contact Sky to get it swapped. If you do need a new box remember to remove the viewing card from the faulty box.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Sb71
Level 0 icon
Re: Box overheating
Yes well ventilated
thank you I will request a replacement
This message was authored by: Nimbob
Re: Box overheating
Hi @Sb71
I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Thanks,
Scott
Community Moderator
This message was authored by: Addie15
Re: Box overheating
Hi there! Thank you for escalating this. We have sent an invite to @Sb71;
