903
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Q Apps pixelating
Locked
Re: Sky Q apps (Disney, Prime, etc) showing intermittent artifacts
@AlanB66 wrote:
I have recently started noticing artifacts /frozen-frames (?) occuring on playing programs, noticably on Disney+ and Prime (I've not used Netflix for a while), and don't notice it on normal Sky-TV or recordings viewing.
I've already updated the sky-q software version via settings but this made no difference.
You can see an example of this (videoed using a phone - so sorry not great quality, and I've got rid of the sound) on :  https://1drv.ms/v/s!Ar58ktrJaNcTgbdImE8_pQ7A_IWNKg?e=5ke2SO
Does anyone know how to resolve this?
@AlanB66  I have moved your post in to a large thread all about the same problem you have. Sky are investingating this
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: HOWARDWWW
Re: Sky Q Apps pixelating
Sadly despite new Q box and latest software update pixilating still occurring on Disney + app
This message was authored by: BWAWAW
Apps are pixelating
Having issues watching Apps, lots of pixelating
tested Broadband and Wi-Fi all looks as it should
Re: Apps are pixelating
@BWAWAW
Your post has been moved into a thread discussing this issue.
This message was authored by: Rambhi
Getting same issue. Pixelated issue fixed. Netflix works fine but prime crashes after 10-20 mins in and exactly like you I have to back out using the home button. It's simply crashes now.
This message was authored by: JFin
Same problem, I've just bought a new TV 😩
£100+ a month for sky (not even broadband) and it's doing this! 😡
This message was authored by: Macculus
I've now started seeing pixelation and artefacts on Sports+ matches (the software introduction of which is the root cause of all the issues, I think) . This is a service supplied directly by Sky and although it's not as unwatchable as, say, Disney+, it is still unacceptable. Can we have an update please Sky?
Yes since sports+ was introduced the fixes stopped working again. I don't get pixelated picture but apps crash at random and it happens through Disney app the most. Works fine for about 30 mins.....
This message was authored by: JibbaJoy
I watched a sports+ footie game the other day and I thought it was awful (the picture & sound quility not the game) ; the crowd noise sounded like it was muffled and the picture wasn't even HD standard. No pixelation though!
SkyQ [H/W: 32B106] + 3 mini
Samsung 55" Neo QLED UHD TV
Swish Fibre 150 Symetrical
Linksys MX5400 Mesh network
This message was authored by: Darkson
On one hand I'm glad I'm not the only one with this issue.
On the other hand, a 53 page thread with seemingly no fix in sight is not a great look for Sky.
Well at least your new TV will have the apps to use 😉
This message was authored by: Bob+Niro
Has anyone noticed a slight improvement recently? Granted I have been using local apps for past few weeks but last night I decided to watch Netflix and Prime through Sky. In a 50 minute series netflix pixilation occured just once. I'd hardly have noticed it only for I was keeping an eye out for it. For a similar lenght of time on Prime there were three very short pixilation occurences. I thought it had been worse previously. It seems to be worse for some customers and are some apps more affected that others?
I spoke to a Sky rep in ROI yesterday and he said that as they don't have wider reports of a bigger issue they are invesitaging each complaint separately. The first thing he suggested I try was change my preference from ECO to Active as othe ECO mode can sometimes affect updates. He is going to leave it for 2 days and if no improvement try something else. He wants to rule out possible issues one by one with the very last option changing the box. I see his logic and am happy to go with it.
Mine is definitely better than before but still occurring, I'll investigate the 'active/eco' thing.
Sure does!
This message was authored by: JCT9632
Where do you find these settings?
Locked
Answered - Go to Answer
