154
This discussion topic has been answered Discussion topic: Pause / rewind issue 16/09/25
Avatar for Daniel0210
Level 16 icon
Re: Pause / rewind issue 16/09/25
@Willow+1000
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: for any customer whose services are restricted due to a missed payment phone contact is unlikely to work.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note ~ ROI customers 🔹If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
This message was authored by: Willow+1000
Thanks. Much appreciated.
This message was authored by: KevNewMedia
Posted by a Sky employee
Hi Everyone
Thank you for your patience whilst we worked through this fault.
Our support teams have confirmed that the issue has been resolved. We're sorry for any inconvenience.
I'm going to mark this post as the current answer, so that everyone has the most up-to-date information.
Kev
Community Manager
Thanks for the info. However, why isn't this confirmation regarding sorting the issue made more public? Not everyone uses sky community?
This message was authored by: PJG70
Well we pay so much per month I have seriously thought of ditching the whole shebang! We actually watch so little but the planner and record element is useful.
Yes it's far too expensive, however, I do enjoy it. I'm retired and it's my only company so I'll hang on to it. I was considering their streaming PUK thing, but I've heard it's terrible!
This message was authored by: KevNewMedia Answer
Hi Everyone
Our support teams have confirmed that the problem is now resolved. Is that the case for you all?
Kev
Community Manager
Yes thanks. But why was this not distributed nationally, so that Sky customers could understand the issue was due to Sky, so they didn't doubt their own equipment?
The problem wasn't a national issue, it didn't impact all customers. Thank you for confirming that it's resolved for you @Willow+1000
Kev
Community Manager
Thanks for your response, however, numerous customers, like me, went on to make various unnecessary adjustments to their settings in an attempt to rectify the error. Some even reset their sky boxes and lost all of their recordings and downloaded data in an attempt to rectify an error which was down to Sky. They thought their equipment was at fault! Surely in this day and age, Sky are able to let the affected customers know that the error lay with Sky and hold on until the error is rectified?
This message was authored by: Jallen26
Think your support teams need to have another look at this issue...it's 7.39pm on 24.08.25 and still unable to pause/rewind live shows...this is suppose to be one of the benefits of digital tv!!!
...typo- 24.09.25
That's nuts. Either the sky issue still exists or your hard drive is playing up. I don't have any issues now. Hope you get it sorted.
@Jallen26 Have you tried rebooting your main Q box ie
Yes agreed that may work. The old switch off for a while then switch back on often helps by resetting the system. Good luck.
Answered - Go to Answer
