156
This discussion topic has been answered Discussion topic: Pause / rewind issue 16/09/25
Post created to amalgamate posts on this issue.
Sky are aware of it.
This message was authored by: KevNewMedia Answer
Re: Pause / rewind issue 16/09/25
Posted by a Sky employee
Hi Everyone
Our support teams have confirmed that the problem is now resolved. Is that the case for you all?
I'm going to mark this post as the current answer, so that everyone has the most up-to-date information.
Kev
Community Manager
This message was authored by: Roger769
SkyQ: Live pause not working for channels 101-105
My SkyQ box won't pause this morning. I have tried unplugging and restarting. Can anyone help please?
Moderator note: subject of thread updated to better reflect the conversation
This message was authored by: CSH123456
Re: SkyQ Pause not working
Mine isnt either, I have unpluggged and plugged in again. It appears not to work on the 'terrestial' channels, BBC, ITV, etc. but does work on the Sky channels, Sky News, Atlantic, etc.
This message was authored by: Mandee1
No Pause or Rewind???
My pause and rewind don't work??
Re: No Pause or Rewind???
hi @Mandee1
This seems to be with the main free channels & happening for SKy Q customers also
see this
https://helpforum.sky.com/t5/Sky-Q/SkyQ-Pause-not-working/td-p/5086836
This message was authored by: Adi1961
Pause
Sky q box won't pause
Hi @Roger769 @CSH123456
Thank you for making us aware of this problem and thank you @Quoman7 for tagging us.
We have escalated this problem to our support teams and will give you an update as soon as we know more.
Kev
Community Manager
Re: Pause
hi @Adi1961
As you will see I have moved your post onto another discussing this - please see the reply currently marked as Answer to advise SKY are now aware
@nigea99 wrote:
hi @Mandee1
see this
@Mandee1
Please also see this post stating that SKY are aware - you may wish to subscribe to that discussion so you receive updates
SKY Q report
This message was authored by: brenda+gregson
Re: Unable to pause/rewind live tv
I am unable to pause or rewind any program
This message was authored by: Lotty10710
Unable to pause or rewind live TV
This morning I have been unable to pause or rewind some of the tv channels (bbc, itv sky kids etc) yet I could pause sky movies. I followed the instructions to access the hidden reset menu and did the first reset only. The problem now is my Bluetooth remote is no longer connected and the screen brings up accessibility settings on the screen which require me to select an option. I can hear the Sky Intro channel in the background but cannot reconnect my remote until I get through this screen but I cannot get past this screen as the remote is disconnected. So I am unable to see if the pause issue is fixed as I now have this other issue
Re: Unable to pause or rewind live TV
hi @Lotty10710
The pause/rewind problem has been reported.
Unfiortunately the reset of your box means you need to reset  the remote  to dismiss the message & then re-pair your remote
To reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
You should now be able to dismiss the accessibility message
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
This message was authored by: Jwilliams61
Pause and rewind not working
Pause and rewind is not working on my sky q box channels 1-5 only. Please help
Re: Pause and rewind not working
hi @Jwilliams61
This message was authored by: JohnRankine
I have the same problem this morning as well, is the fault at Sky's end?
