Discussion topic: No tv after storm
This message was authored by: CJax09
No tv after storm
No tv, no sky tv either can't use apps like netflix
Re: No tv after storm
Have you tried rebooting your Q box @CJax09
This message was authored by: daveNOS
@CJax09 It's hard to advise when so little information is given.
What if any error messages are showing on your TV?
This message was authored by: Mica.
My tv went fuzzy then now blue screen says no signal
Ive tried turning tv off unplugged it all put it all back on and nothing still the same been like this for 40 mins now and nothing
Hi @Mica.
@Check out the following link
Ive done all that and just says i have to book an engeneer and earliest date is wednesday
@Mica.
Sounds like that's what you'll have to do. He/she will check your dish alignment
But means i have no tv until wednesday and i have a child we need a tv
If Wednesday is the earliest date then you'e actually very lucky, until then there really isn't anything else the forum can do to speed this up.
@Mica.
To be honest a wait of 3 working days is pretty good. You'll have been given the next available engineer slot in your area.
Yea but not a problem if im on my own but with a child is crazy so we have to sit in silence and rely on our phones for 3 days
@Mica. Unfortunately that's one of the downsides of pay TV, if you don't want to wait for Sky to send out an engineer you could always pay for a local independent installer/engineer to see if they can sort the problem out.
This message was authored by: Doc5907
@Mica.you need to consider, as a backup, having a terrestrial aerial connected to your TV so if your satellite system fails, as has happened in your case, you can watch all the Freeview channels.
Of course, if you have a smart TV and working broadband you can stream the likes of itvx and iPlayer and providing you you have subscriptions you can watch the likes of Netflix and Amazon Prime.
So potentially you shouldn't have to sit in silence..
Sky Q 1TB UHD
LG TV
Sky Mobile
This message was authored by: Skull+Treaty
Yup, I have to wait until next Thursday and reported ours on Wednesday this week!
