18
This discussion topic has been answered Discussion topic: No signal
This message was authored by: DCo11in5
No signal
I have always had a sky hd box in my bedroom running on free sat and when we changed to sky q in the living room it was set up to carry on free sat in the bedroom on the same box but several months later it's stopped working and says no signal. Can anyone help
This message was authored by: Mark39 Answer
Re: No signal
Assuming that's no satellite signal, it means there's a problem somewhere between your Sky box and the dish. It could be the cable, the connectors at either end of the cable, the LNB (where it connects at the dish) or the,box itself. Turn the box off at the plug and check that the dish connection at the back of the, is secure. You could try unplugging and reconnectng the connector, but do it,carefully, as it's easy to bend the centre 'pin' inside the plug.
Re: No signal
Avatar for DCo11in5
Re: No signal
I have tried all the above before with no luck but can look again
This message was authored by: English+B
Re: No signal
Thanks  I already did but still nothing
Re: No signal
What did you end up doing
Re: No signal
@English+B
No signal normally comes from your TV, no satellite signal normally refers to your Sky box. Have a look at this link
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
If that doesn’t help you, at the end of the link it should give you an option to arrange an engineer to check your dish alignment.
Re: No signal
Thanks, will give it a try
This message was authored by: PrimroseCottage
Re: No signal
All working now
thank you
This message was authored by: Treek
Re: No signal I have no picture
Teresa vernon I have no signal  on my screen
@Treek
As per my post above, ”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
@Treek
Your duplicate thread has been removed. The appropriate advice has been posted on this thread.
@Treek
For some reason you don't appear to be reading our replies. Your 3 further posts saying the same thing have been removed. Your question has been correctly answered.
I still have no signal Re: No signal
I can't get rid of the  no signal  on my Telly screen.
Re: I still have no signal Re: No signal
@Treek  Have you read any of the replies posted in this thread??  If not then you need to follow the steps provided in detail in the replies above.
My sky is not working I can’t adjust the dish as I’m 82 and can’t climb ladders.
My sky has no picture and my dish  needs looking at I can't climb a ladder to inspect it I am 82 years old and have been with sky a long time VIP I need an engineer to make it work again please send one !! I miss my sky . Terri
