Discussion topic: Move sky q box
This message was authored by: Libby12
Move sky q box
I would like to move my living room around however my tv cable isn't long enough. Which is the right extension to buy? I have seen online a twin one but I don't have that on my sky q box currently.
Re: Move sky q box
Hi @Libby12
If you are on a communal system and do not have your own dish then there is normally only one cable.
You can buy singles cables as well as pairs.
https://www.amazon.co.uk/G-PLUG-Coaxial-Cable-Connectors-Ring-White/dp/B08LN7TMTD/ref=asc_df_B08LN7T...
Avatar for Libby12
Re: Move sky q box
Ok thank you for your help. I'll order this now!
