This discussion topic has been answered Discussion topic: No signal
Message posted on 24 Jun 2023 03:33 PM
I have always had a sky hd box in my bedroom running on free sat and when we changed to sky q in the living room it was set up to carry on free sat in the bedroom on the same box but several months later it's stopped working and says no signal. Can anyone help
Message posted on 24 Jun 2023 03:59 PM - last edited: 24 Jun 2023 03:59 PM
Assuming that's no satellite signal, it means there's a problem somewhere between your Sky box and the dish. It could be the cable, the connectors at either end of the cable, the LNB (where it connects at the dish) or the,box itself. Turn the box off at the plug and check that the dish connection at the back of the, is secure. You could try unplugging and reconnectng the connector, but do it,carefully, as it's easy to bend the centre 'pin' inside the plug.
Message posted on 26 Jun 2023 10:47 PM
Re: No signal
I have tried all the above before with no luck but can look again
Message posted on 17 Jul 2023 04:51 PM
Re: No signal
Thanks I already did but still nothing
Message posted on 17 Jul 2023 04:53 PM
Re: No signal
What did you end up doing
Message posted on 17 Jul 2023 05:04 PM
Re: No signal
@English+B
No signal normally comes from your TV, no satellite signal normally refers to your Sky box. Have a look at this link
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
If that doesn’t help you, at the end of the link it should give you an option to arrange an engineer to check your dish alignment.
Message posted on 17 Jul 2023 05:38 PM
Re: No signal
Thanks, will give it a try
Message posted on 23 Oct 2023 10:35 AM
Re: No signal
All working now
thank you
Message posted on 16 Nov 2023 02:31 PM
Re: No signal I have no picture
Teresa vernon I have no signal on my screen
Message posted on 16 Nov 2023 02:36 PM
As per my post above, ”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
Message posted on 16 Nov 2023 02:46 PM
Your duplicate thread has been removed. The appropriate advice has been posted on this thread.
Message posted on 16 Nov 2023 07:58 PM
For some reason you don't appear to be reading our replies. Your 3 further posts saying the same thing have been removed. Your question has been correctly answered.
Message posted on 16 Nov 2023 08:02 PM
I still have no signal Re: No signal
I can't get rid of the no signal on my Telly screen.
Message posted on 16 Nov 2023 08:03 PM
Re: I still have no signal Re: No signal
@Treek Have you read any of the replies posted in this thread?? If not then you need to follow the steps provided in detail in the replies above.
Message posted on 17 Nov 2023 10:47 AM
My sky is not working I can’t adjust the dish as I’m 82 and can’t climb ladders.
My sky has no picture and my dish needs looking at I can't climb a ladder to inspect it I am 82 years old and have been with sky a long time VIP I need an engineer to make it work again please send one !! I miss my sky . Terri
