Discussion topic: No satelite signal
Message posted on 10 Jan 2026 09:29 AM
Re: Mini boxes not getting signal
Have now sorted by unplugging the main sky box and restarting. All checks on the app said all in good working order, so this was the only thing I hadn't tried. Obviously it was blocking sending the signal to the mini boxes. Good luck and fingers crossed.
Message posted on 10 Jan 2026 09:31 AM
Re: Sky mini box ‘activation’ issue!
@Pinkyxxxx wrote:My mini box still not working
Unplug q for 39 secs. Plug back in and let that boot back up. Once all ok do same with mini. Should would. Just tried it and worked for me
Message posted on 10 Jan 2026 09:32 AM
Re: All mini boxes are down
This has worked for me thanks
Mini box
Done multiple resets. But my sky mini box still says no signal even though its connected to main box and strong Internet signal. How do I contact a human at sky to help
Message posted on 10 Jan 2026 09:35 AM
Re: No satelite signal
I had exactly the same issues, service app said all good, box settings said good signal and that I didn't have sky go or mini boxes in my account. Tried everything I could from is the box asleep to ice on the dish. It's not a customer fix I think, everything just reappeared , I went out for a walk rather than throw the box out the window!
Message posted on 10 Jan 2026 09:37 AM
Re: No satellite signal on sky q mini box
I'm in Tewkesbury, Glos, and I have the same issue.
Message posted on 10 Jan 2026 09:38 AM
I can't get my minibox back up & running.... I've tried unplugging it, resetting it reactivating it to the main sky box but no channels. I can get all the apps tho
Re: Sky mini boxes
Message posted on 10 Jan 2026 09:42 AM
All on again in Maidenhead. I had to switch off every box and restart them to get the mini boxes to reconnect ...
Works now thank you so much.
So much for Saturday morning coffee in bed though
Message posted on 10 Jan 2026 09:44 AM
Sorted at last.
1. Switched of and unplugged all Sky Q mini boxes
2.Switched of and unplugged Sky Q main box, and waited two minutes.
3. Plugged in and switched on Sky Q main box and set up this box with TV.
4. Repeated performance with each of the mini boxes.
Hope this helps
Re: Sky mini boxes
Working now, switched everything off at the plug left for 30 seconds.
Message posted on 10 Jan 2026 09:45 AM
Mine was down at 6am in Anglesey but came back on at 7:09 am.
Message posted on 10 Jan 2026 09:46 AM
No satellite signal on mini box
Re: Sky mini boxes
