7
This discussion topic has been answered Discussion topic: No satalite signal
This message was authored by: AlvesBird
No satalite signal
Iv taken all the steps and still no signal, on my app it tells me there is full signal, help please 🙏
Re: No satalite signal
@AlvesBird
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
If you've tried all the recommended steps then you will need to call Sky.
@AlvesBird
This message was authored by: 0007
After following instructions given by your help team, India, I have now also lost my recordings...... very angry!
@0007  You're only telling other customers by posting here.
They asked you to wipe the hard disk?  (A strange piece of advice for satellite signal reception issues)
Having done all the obvious, ie checking cables, leads, plugs etc..... that only leaves the dish as the cause. I have no idea if an engineer is booked or what is going on, but I do know that I won't be speaking with India again!  If you ask a question they start all over again with their scripted speech! I just loose the Will to live!!!!!
This message was authored by: Invisiblename
You could always get a local independent in to do it (at your own cost)
I am just another Sky customer!
Answered - Go to Answer
