2
Discussion topic: No satalite signal
This message was authored by AlvesBird This message was authored by: AlvesBird
No satalite signal
Iv taken all the steps and still no signal, on my app it tells me there is full signal, help please 🙏
This message was authored by Daniel0210 This message was authored by: Daniel0210 Answer
Re: No satalite signal
@AlvesBird
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
This message was authored by PandJ2020 This message was authored by: PandJ2020
If you've tried all the recommended steps then you will need to call Sky.
I am just another Sky customer and my views are my own
@AlvesBird
