This discussion topic has been answered Discussion topic: No satalite signal
Message posted on 21 Aug 2024 12:03 PM
Iv taken all the steps and still no signal, on my app it tells me there is full signal, help please 🙏
Message posted on 21 Aug 2024 12:37 PM
@AlvesBird
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 21 Aug 2024 12:15 PM
Re: No satalite signal
If you've tried all the recommended steps then you will need to call Sky.
@AlvesBird
Message posted on 30 Jan 2025 10:34 AM
After following instructions given by your help team, India, I have now also lost my recordings...... very angry!
Message posted on 30 Jan 2025 10:58 AM
@0007 You're only telling other customers by posting here.
Message posted on 30 Jan 2025 11:09 AM
@0007 wrote:After following instructions given by your help team, India, I have now also lost my recordings...... very angry!
They asked you to wipe the hard disk? (A strange piece of advice for satellite signal reception issues)
Message posted on 30 Jan 2025 06:13 PM
Having done all the obvious, ie checking cables, leads, plugs etc..... that only leaves the dish as the cause. I have no idea if an engineer is booked or what is going on, but I do know that I won't be speaking with India again! If you ask a question they start all over again with their scripted speech! I just loose the Will to live!!!!!
Message posted on 30 Jan 2025 08:49 PM
@0007 wrote:Having done all the obvious, ie checking cables, leads, plugs etc..... that only leaves the dish as the cause. I have no idea if an engineer is booked or what is going on, but I do know that I won't be speaking with India again! If you ask a question they start all over again with their scripted speech! I just loose the Will to live!!!!!
You could always get a local independent in to do it (at your own cost)
