11
Discussion topic: Netflix viewing issue
This message was authored by guardian1128 This message was authored by: guardian1128
Hi all
Was watching a couple of things on Netflix via the sky q box as per usual, afterwards I decided to look for something else to watch, found something and clicked on it, went to the program screen and clicked on play then got a blue screen which was showing a connection speed test which said it was fast enough but wouldn't play, just showed an error message in the bottom right of the screen.
code tvq-pb-101(1.9.0)
Doesn't matter what other film or tv show i try to watch it now does the same thing all the time, all other apps like youtube, prime video, paramount etc all work and play fine, Netflix on my laptop and mobile phones all work fine, just not on the sky q box which was playing fine earlier today, unplugged the box and the router and reset multiple times but still goes back to the same test screen and error code message, no idea what to do next, nothing i've seen happen before.
Any ideas?
guardian1128
This message was authored by guardian1128 This message was authored by: guardian1128 Answer
Re: Netflix viewing issue
Ok peeps
Just checked it again now during the end of 1st quarter NBA game, and Netflix now seems to work perfectly again, tried several different progs and all ran straight away, happy days.
Case closed. 😀😃
This message was authored by Del1954 This message was authored by: Del1954
Same problem, Netflix won't connect, been watching for the last 2 hours now nothing
This message was authored by MelCB This message was authored by: MelCB
We have the same problem, new to Sky but all set up downstairs a week ago. Tonight I set up my sons TV while he was at the gym, watched the beginning of a film no problem. He switched on two hours later, and no Netflix, can't get it to work for love nor money! All other apps seem to be ok though 🤷‍♀️
guardian1128
Not just me then, looks like an issue on skys end, i'll check again in the morning, if it's working then i'll reply back here and mark as solved, if not then i'll call sky and ask them what's going on and see what can  be done about it, 🤔
guardian1128
Ok peeps
Case closed. 😀😃
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
FYI there was a global Netflix outage last night: This report only mentions the UK but they were hit globally: https://www.reuters.com/business/media-telecom/netflix-down-thousands-users-downdetector-2023-12-12/
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
This message was authored by Modimav This message was authored by: Modimav
I still can't get Netflix to work. Any further updates or suggestions? Thanks
@Modimav @What do you mean by not work?
have you tried Netflix on a different device? What sky device as you trying it on?
NOT a Sky Employee
On the TV. It will not connect, just spins. Thanks
Have you tried from another device?
NOT a Sky Employee
Thanks for the advice. It is back up 😊
Thank you so much for confirming.
My neurodiverse children could not cope or understand what was happening and I couldn't fix it so it was rather stressful. At least I know now that it was an outage an nothing to do with our new Sky system.
