Discussion topic: Connection error
This message was authored by: Sajb786
Connection error
Hi over the last few days my mini box loses connection with my sky Q box. This lasts about five minutes. But is now happening several times a day
Re: Connection error
Hi @Sajb786
Reboot the mini as above.
