2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
Re: Netflix won’t load on sky q mini box
@Simtra64 wrote:
Netflix won't loaf on mini box red circle have done app reset.
Works fine on q box
Try my post (#2252) further up the previous page first.
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4711316#M658235
This message was authored by: Delbo
Hi we can't get netflix on our skybox it just keeps spinning
Hi I can't get netflix on my lounge skybox it just keeps going round
Re: Hi we can't get netflix on our skybox it just keeps spinning
Hi @Delbo
I have moved your post to, the main discussion on this
Please see the post currently marked as an Answer for details to help
Edit : @Delbo I have also removed your duplicate post
This message was authored by: Catboyd
NETFLIX
Netflix has not been working for many months on the Sky Q Box.  At first, if I rebooted the sky box, Netflix would work - eventually Netflix would not load.
I have tried refreshing the app on the Sky Q box. I have tried the option of logging on to netflix via a web browser and logging out of Netflix that way - reboot etc etc.
None of the tips or recommendations so far have worked.
Is there any other options to try and Netflix up and running again.
thank you
Re: NETFLIX
@Catboyd
Are you seeing a red spinning circle?
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
Re: NETFLIX
@Daniel0210 yes I am
Re: NETFLIX
@Catboyd
I've merged your post into the large thread discussing this issue that some customers are experiencing. See the post currently marked as the answer (post 2) and other possible temporary fixes.
Re: NETFLIX
thank you
When logging into Netflix online you are removing the Sky devices from the account and not just logging out of Netflix? You don't log out of the Netflix account online at all.
This message was authored by: Vix6
Netflix not working
I have been unable to watch Netflix (app won't open) for a couple of months now.
This message was authored by: Niki+456
Hi for some reason Netflix won’t load anymore, I have tried resetting everything I can , unplugging
Hi I can't load Netflix any more, I have reset everything and unplugged everything but still no joy. All othe apps are fine
Re: Hi for some reason Netflix won’t load anymore, I have tried resetting everything I can , unplugg
Any help: https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4694387#M654564 ?
Re: NETFLIX
thank you
Yeah this is something I see time and again, people talking about "logging out of netflix" when they should be signing out the Sky boxes via the account menu. I suspect, like you, that they are doing the wrong thing and not just naming it wrongly.
Re: NETFLIX
thank you
I've only just noticed myself that there's a 'show more' button under the 'manage devices' option as it only shows 4 devices by default, I had an old browser listed there. I think it may help people to just remove ALL devices to make sure they're doing it correctly. Other than that, I can't see how it can be made clearer.
Locked
Answered - Go to Answer
