Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 10 Sep 2023 04:20 PM
Re: Netflix on sky q will not load
Okay, long post...
A probably somewhat reliable (but slow) solution
Open the Netflix App, wait 10-20 seconds to see if it loads. If not, close the app. Open any app other than Netflix. Close that app. Open Netflix again. Repeat maybe a dozen times, until it works.
What's the problem? (mostly guesswork here)
The Netflix app is really two systems: the "client" on your actual box communicating with Netflix's server. Since the problem seems to have appeared on all kinds of user-side machines without being tracable to a particular update, it is very likely that the change happened on Netflix's end. The problem also only appears while starting the app, so it's likely related to the login process. At least for me, the problem appeared around the time Netflix announced that they would crack down on multi-household accounts. It's possible that they are doing that by adding another step to the logon protocol, one that is only sometimes required. If that's the case and the Netflix app on your box does not support that step correctly yet, it will simply fail and continue to "load". But again, this is just a best guess.
Why do some solutions seem to work?
IF this explanation is correct, it's really just a matter of repeating the process until it works. But for that, the Netflix app needs to be completely closed after every attempt. By default, it seems to remain active in the background and thus you are not actually starting a new login attempt every time you open it. Solutions like software updates or system reboots will obviously shut the app down. It's much easier, though, to just briefly open another app because it seems that only one app can remain active in the background at a time.
What can we do long-term?
Not much, really. Netflix and Sky (or whoever is developing the app itself) need to sort this out and probably roll out a patch. For that, they need to actually be aware it is happening.
I hope this is helpful to anyone. No guarantees about anything.
Message posted on 10 Sep 2023 06:17 PM
Netflix is a very complex web of
microservices, some of which are being upgraded / tested with different customers at different versions. However, the basics of opening the app should just work for everyone and it's not happening on all kinds of user devices is it? Just on Q (at least as far as this thread has revealed)
Message posted on 10 Sep 2023 06:31 PM
You would think Netflix would test out it's service with Sky wouldn't you?
Nah! Much to obvious to do that 😅😅😅😅
Message posted on 10 Sep 2023 06:38 PM
@MarkJ22 wrote:You would think Netflix would test out it's service with Sky wouldn't you?
I have just done it on their behalf and it worked. Showed list of profiles within 2 seconds. Happy to help 😉
Message posted on 10 Sep 2023 06:52 PM
Yes, many of us get the same from time to time but sadly it's not all the time and if you've just settled in to watch something and it won't load it's very frustrating.
Maybe, as you're a SUPERUSER you could bring your influence to bear in Sky to get this issue sorted out for the majority of us who have posted here and the many others out there with the same issue?
Message posted on 10 Sep 2023 06:57 PM - last edited: 10 Sep 2023 06:58 PM
@MarkJ22 wrote:Yes, many of us get the same from time to time but sadly it's not all the time and if you've just settled in to watch something and it won't load it's very frustrating.
The idea that I have any influence whatsoever is heartwarming 🙂 I have no doubt it's linked to the Q's wild and unique networking code. I gave up on wifi and can only recommend everyone else does the same.
fwiw Netflix always works for me (luckily as the 2 TVs with minis are not Smart enough to have Netflix) but iPlayer almost never works.
Message posted on 11 Sep 2023 11:26 AM
Netflix not loading
I have a separate Netflix account which I access through the Apps on my Sky Q however lately it just won't load. The front page comes up with just the loading ring going round forever!! I've tried all the steps and checks provided by Sky on the website including refreshing my apps but nothing seems to make any difference.
Does anyone else have the same issue and is there another solution out there that I haven't tried yet?
Message posted on 11 Sep 2023 01:36 PM
Re: Netflix not loading
Have you tried logging into your Netflix account via a web browser and force signing out of one or more of your faulty devices.
Read this Netfix article on how to do that.
https://help.netflix.com/en/node/128180?q=Remove%20devices
Would suggest, once you have done that, you perform a power reset of your Sky Q box, leaving off power for a few minutes before trying again.
Message posted on 11 Sep 2023 08:47 PM
@Sarah2714 @I've had this issue since switching to fibre. Tried rebooting and the reset apps, nothing working again. It's hit & miss, sometimes it loads, sometimes doesn't. Time to cancel me thinks, paying for a service I can't use is not something I'm up for!!
Message posted on 12 Sep 2023 07:54 AM
I've been trying to recall if I had the Netflix issue before I switched to Sky Ultrafast 1 back in May but for the life of me I can't. Mine has been fine for a few weeks now since I passed on some App details to a Sky employee on here (presuming that's what resolved it).
Is everyone who has this Netflix problem on Sky fibre (or even just Sky/NowTV broadband)?
Can anyone who does have this and who has a computer hardwired, try speedtest.net on the browser and then try the speedtest App from the Windows store? The App on my desktop gives speeds all over the place whilst the browser version always returns 150Mbps.
Message posted on 12 Sep 2023 03:12 PM
I had the same issue yesterday and the old switch off your device, wait 5mins then switch back on worked for us
Message posted on 12 Sep 2023 04:49 PM
Re: Netflix crashing Sky Q
Its clearly an issue as three of us are having exactly the same problem. Why aren't any Sky Experts responding ?
Really poor .
Message posted on 12 Sep 2023 05:06 PM
Really poor .
@Markgunners in case you are not aware this is a customer to customer forum where customers help each other.
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Message posted on 12 Sep 2023 05:49 PM
Hello, just logging that I have the same problem and i only had Sky Q installed yesterday after 20 plus years of Sky+ that's why i am here now - not a great experience.
I have tried all the solutions above plus, everything is up to date and everything else i have searched for and can think off it has not helped .It just loops around throwing up random error messages after 30 seconds or so of trying to connect.
Netflix works fine on every other device i have all connected to the same network and never had any issues with them .
Some of the error codes i have seen, i am sure there has been others, top one most common.
NW-2-5 (means that there is an internet connection problem) I don't
NW-8-14 (typically points to a network connectivity issue that is preventing your device from connecting to the Netflix service) All other devices in my house and there are many connect fine to Netflix.
I hope this does not drag on.
Message posted on 12 Sep 2023 07:49 PM
I'm having this issue reboots fix it then couple of days later falls down really poor service.
sky please look into this issue
