1722
Discussion topic: Netflix: Red Spinning Circle on Launch
This message was authored by Nile2977 This message was authored by: Nile2977
Re: Netflix: Red Spinning Circle on Launch
Pretty much tried everything mention here. Router off. App refresh. Q box on/off etc. 1 thing I did do not mentioned elsewhere was go into netflix account via Internet. Sign out your Q box. Then turn off your sky q. Reset button first. Turn off. Leave five minute. Let load up like normal and netflix worked fine. I dont know worth a try. Wonder if it loses the link and signing out forces sky q to sign it back in?
This message was authored by Chodley This message was authored by: Chodley
That's what we've been saying repeatedly but it's further into the thread that someone spotted it so you probably didn't get to it as it's a beast! 🙂
Don't think it loses the connection but we think maybe the authentication token gets corrupted or something and when it has to request a new one...
This message was authored by Letitia2 This message was authored by: Letitia2
Netflix problems
Every time I try and load Netflix it stays on the loading screen I turn it off and on again still the same last time it took nearly an hour to work
This message was authored by Colin0000 This message was authored by: Colin0000
@Bob123 wrote:
Signing out the SkyQ box in the Netflix app then powering off for a few min and back on worked for me 👍
Good to know that both you and @Nile2977 have had success with the easy solution that seems to have worked for many. I do wonder if the few that it didn't work for failed to reboot the Q box after removing the Q box from devices online.
Much, much easier than most of the other "solutions" which don't appear to work.
Sky Q 2GB 32B106 - HDMI to TV, hard wired to router with WiFi disabled on the Q box
VM 256Mbps via rubbish VM HUB 3 router
Samsung S95C 55"
It was bugging me that I couldn't remember who came up with the 'fix' in the first place and I've been trolling through the thread looking for the first mention. It was @Sam9999 👍 at the end of November last year (although it seems longer than that 😉 )
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4495318/highlight/true#...
I would reboot the Q box after removing the device from the Netflix account however.
I still don't know what Sky did to my account (delete the authentication token remotely maybe?) at the end of July or start of August last year but it's been perfectly fine ever since.
Samsung S95C 55"
This message was authored by Johnnymc1 This message was authored by: Johnnymc1
Thanks for the posts everyone, did the 001 and reset apps yesterday thank you for that info worked at that time just went to go on Netflix and its gone again so will try the log out and reset advice given by a few with thanks
Hi have signed out of netflix and reset q box re paired remote all working for now test will be tomorrow when go back thanks to all
Kind regards
This message was authored by PhilFisk This message was authored by: PhilFisk
Netflix won’t load
Netflix wont load from App on Sky.  Broadband check is saying ok, but Netflix wont load today.  Working intermittantly at the moment.
Should not need to reset settings on the Q box after force-logging it out, just reboot it.
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Re: Netflix won’t load
What Sky TV service do you have as you have posted this in the Sky Go forum, which is itself an app so has no link to Netflix at all?
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
This message was authored by Budlou11 This message was authored by: Budlou11
I'm waiting to for 2 TVs to be added to my devices. A TOSHIBA and a SAMSUNG many thanks Louise Aldous
This message was authored by Darrenhavers This message was authored by: Darrenhavers
Netflix won’t load
Hi
ive been having problems with my Netflix on my sky q box it just won't load however on my mini box in bedroom it loads straight away! Anyone got any fixes for this for the main box? I've tried the usual unplug reboot even the hidden refresh and still nothing works?
This message was authored by 100PHOENIXX This message was authored by: 100PHOENIXX
Re: Netflix issue
Sky q won't load netflix
This message was authored by Stalest This message was authored by: Stalest
I too have had intermittent red circle spinning until the last couple of days when it was permanent. I tried the app refresh and reboot of my skyQ box to no avail. But I finally got Netflix working by going into my Netflix account on a web browser and resetting my sky box on the devices part of my account, and then rebooting my sky box.
I followed the instructions from Colin0000‎ (post 1569)
Log into Netflix via the web browser.
Highlight your profile picture (Top right corner).
Click on Account.
Under the Security and Privacy option, click on 'Manage access and devices'.
Select the device name: (it may be called SkyQ ......or Sky UK Set-top box).
Select--> click on the "Sign out" option on the SkyQ ......or Sky UK Set-top box.
Reboot SkyQ box by turning off at the wall or plugging out for 1 minute.
Go to your SkyQ box and launch the Netflix app on your SkyQ box.
@Darrenhavers wrote:
Hi
Read the last page of posts. Like @Stalest did.
