30 Sep 2023 05:30 PM
@Eddy99 wrote:
@blobsieUnfortunately she has a record of doing this when there is no answer, i have seen this before by the same person - jumps on one persons suggestion with no evidence it works for anyone.
@Eddy99 maybe if you had read the post correctly you would see that as @Mark187187 has stated that @Kirsty+S27 merely marked her post as the answer so it was easier to find and also asked for anyone having this problem to comment as to whether trying the fix in her post fixed the problem or not as it would help the team that is investigating this
30 Sep 2023 05:33 PM
@Laing1 - Thanks for the support Mr Superuser, we are not all as smart as you.
30 Sep 2023 05:39 PM
@Eddy99 wrote:@Laing1 - Thanks for the support Mr Superuser, we are not all as smart as you.
Support? All you had to do was read her post, not rocket science is it?
30 Sep 2023 05:40 PM
Thank you tk everyone for the replies and feedback!
30 Sep 2023 05:47 PM - last edited: 02 Oct 2023 07:03 AM by KevNewMedia
@Colin0000- I have reported your post for being a rude [content removed]
Moderator note: language removed
30 Sep 2023 05:48 PM
Come on peeps let's all be nice and focus on the issue and the fix.
It's frustrating that Sky have no solution
01 Oct 2023 09:29 AM
Does anyone have a direct phone number for Sky?
I really can't tolerate this any longer and will be removing Netflix from my package and demanding a refund for the 'service' that I've paid for but have been unable to access for the last 6 weeks!! 😡
01 Oct 2023 09:33 AM
@Kirsty+S27 No, this doesn't work, in fact, my Netflix had started to work via On Demand, but since doing as you instructed via the app, it's stopped loading again!
01 Oct 2023 03:04 PM - last edited: 01 Oct 2023 03:04 PM
@carrie171 wrote:Does anyone have a direct phone number for Sky?
Yeah everyone does. Look in Help on My Sky
You know you can use Netflix on another device?
01 Oct 2023 04:07 PM
@Chodley I am aware of that, but as I only have my phone, I'm not prepared to watch endlessly on that, when I pay to use Netflix on my TV!
01 Oct 2023 04:15 PM
I have been experiencing the same issue of Netflix not loading via Sky Q box for nearly 12 months now.
Netflix is accessible from every other household device via the app or webpage but connecting via the Sky Q box often a NoNo. Not every time though...there have been occasions over the last 12 months when the profile screen has loaded but these are very few and far between, with most attempts resultingin the scrolling circle of death☹️
Spent many hours on the phone with Sky support many months ago who could not resolve and suggested contacting Netflix....Netflix advised not an issue with them and if Sky couldn't resolve the issue probably sits with my internet provided. Plusnet advised not them as I could access Netflix using other devices and the issue of not connecting to Netflix was solely with the Sky Q box. All other apps on Sky Q connect without issue.
Tried all the suggested fixes numerous times and not found a permanent fix. Occasionally Netflix does connect but these instances are few and far between and I am unable to identify any "fix" which works better than others.
One work around that does always appear to work is to bypass my home router and hotspot the Sky Q box via my mobile device and connect the Sky Q box to the internet via my mobile provider. So far a 100% success loading the Netflix app on Sky Q when connecting via mobile. Obviously not an acceptable fix as I do not have an unlimited data mobile plan 🙃. I have therefore tried a factory reset on my router to see if there is any legacy code stopping the Sky Q box connecting to Netflix but no, when Sky Q box connected back to my router it still fails to regularly connect.
Interestingly when I have connected Sky Q to my mobile device and connected to Netflix I can reset the Sky Q back to my home network and Netflix will continue to load to the profile page. However future attempts to connect to Netflix via my home network result in the circle of death returning and subsequent circle of death and connection issue page.
01 Oct 2023 04:46 PM
@carrie171 wrote:@Chodley I am aware of that, but as I only have my phone, I'm not prepared to watch endlessly on that, when I pay to use Netflix on my TV!
Chodley was probably more referring to your TV which is very unlikely nowadays to be anything but a Smart TV with it's own built in Apps. I used ours for awhile until it seems to have resolved itself (or Sky have done something in the background).
01 Oct 2023 04:48 PM
Is your Q box hardwired to the router or using WiFi? If hardwired have you disabled the WiFi on the Q box from the hidden menu?
01 Oct 2023 06:57 PM
It is now on wifi
As part of my "testing" I have previously hard wired the router to the Sky Q box and disabled 5gz with the connection issue remaining then disabled both 5gz and 2.4 and again the issue connecting to Netflix remained.😞
01 Oct 2023 07:02 PM
I don't think any of the solutions being described here make a blind bit if difference and the solution sits with Sky and Netflix
Until the technicians at both businesses accept the issue and resolve it all the "solutions" here are just playing for time
