12
Discussion topic: Moving home
This message was authored by leanne108 This message was authored by: leanne108
Moving home
So i get the keys to my new house on monday 19th aug now i rang sky to sort move date out ect so i can take it with me to be told the house isnt reg registered and I would have to do this first, but it's not a new build. It's an old house so I don't understand why it's not registered. Can someone please help me with this?
This message was authored by MightyQuinn This message was authored by: MightyQuinn Answer
Re: Moving home
Hi @leanne108   Is it on the Royal Mail database? If not, that is the first thing you need to sort out.
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Moving home
What services do you have?  As an aside you need to give 2-4 weeks notice...
https://www.sky.com/moving-home
I am just another Sky customer and my views are my own
Re: Moving home
leanne108
Re: Moving home
When you put post code in with Royal Mail it comes up so unsure why the house isn't registered it was built 1910s
leanne108
Re: Moving home
He never said I have to give notice and I have phone line internet sky q and mobile phone with sky iv been with them 16 year and never had problems
Re: Moving home
Sure, but you are at the mercy of available OpenReach and Sky engineers - the likelihood of being available on 19th is close to zero.
Re: Moving home
I'd contact them again - it may well be they've mistyped the postcode on their system.
Re: Moving home
Take all the equipment with you.  The mobile phone will be fine - only the account address needs updating.
As noted, OpenReach will need to provision the service and a Sky engineer will need to erect a new dish (if required) and connect and test.
leanne108
Re: Moving home
I don't want them out on the 19th I just want to book them in while I'm off work moving house
Re: Moving home
Ok, sure - you'll have to see what slots they have (once they get past the address issue).
leanne108
Re: Moving home
I thought they had to disconnect you and then move it to the new property
Re: Moving home
No... You can remove and unscrew all the cables from the Q box and router.  (You leave the dish behind)
IF the new property has a dish already then it may work as-is.  But for the phone/Internet there's a provisioning step required to enable the line.  (Or even cabling work required to the property if there's no existing line)
leanne108
Re: Moving home
Thank you for your help
