Discussion topic: Remote network failed
This message was authored by: Paul1726
I recently changed from sky broadband to another provider and now I can't download any programmes..
Ive read the previous threads and still no wiser to the answer??
had anybody got a fix for this??
Re: Remote network failed
Hi @Paul1726
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Avatar for Paul1726
Unfortunately that didn't work!!!!
What happened when you carried out the Network reset on the Q box @Paul1726?
Avatar for Paul1726
I reset it then selected the router and added the password and then it connected via WiFi and then I tried downloading something and it said it failed...
Hi @Paul1726
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
This message was authored by: Greenfingers001
Thanks for escalating this. We’ve sent @Paul1726 an invite to chat.
