This discussion topic has been answered Discussion topic: Is snow affecting Sky Q
Message posted on 05 Jan 2025 11:20 AM
Re: SNOW
@Timot40 wrote:Still never improved on these conditions
Never will - it's intrinsic with dish transmission.
The Q box does have many apps and catch-up that allow you to access most material without a dish. Some of them allow live channels, such as iPlayer. Not quite glass/stream but close.
Message posted on 05 Jan 2025 11:24 AM
Re: Is snow affecting Sky Q
Yeah maybe just unlucky timing. Apps should work.
Message posted on 05 Jan 2025 11:25 AM
My sky is back on.
Message posted on 05 Jan 2025 02:18 PM
same here...now the snow has stopped.
Must have been blocking the satelite signals in heavy snowfall.
Message posted on 05 Jan 2025 02:27 PM
Re: SNOW
Some of us can't get fast enough broadband speeds for live 4k streaming.
Message posted on 05 Jan 2025 02:31 PM
Re: SNOW
Unless that changes, or you stick to HD streaming perhaps, you're stuck with a satellite service, then. That is, until the satellites expire at around the end of the decade.
Message posted on 05 Jan 2025 04:00 PM
Re: SNOW
I had no sky reception via dish and could t even watch recordings from my planner. Rebooted Sky Q box and all now working so even if snow an issue try a reboot.
Message posted on 05 Jan 2025 04:29 PM
Sky satellite signal has gone on sky box.e her i judt have to ac
Satellite signal is down. Bad weather and I just have to accept it. Well I'm not happy because it is a live football match I'm missing
Message posted on 05 Jan 2025 04:32 PM
Re: Sky satellite signal has gone on sky box.e her i judt have to ac
Presumably the bad weather is snow or low cloud cover so your post has been moved into this thread on the subject. Unfortunately there's nothing you or Sky can do about it.
Message posted on 05 Jan 2025 04:53 PM
@Lewyk wrote:Satellite signal is down. Bad weather and I just have to accept it. Well I'm not happy because it is a live football match I'm missing
Sky Go?
Message posted on 05 Jan 2025 05:13 PM
I have not had a signal all day. I assume it's the snow.,
Message posted on 05 Jan 2025 05:41 PM
Message posted on 05 Jan 2025 07:22 PM
I've not had a satellite signal since turning the TV on at 4pm. Can't see how it's the weather as there is no snow on the dish and there is no wind. Had this problem a few weeks back and an engineer came out and said it was because we had too many recordings! I've only used 18%!
Message posted on 05 Jan 2025 07:38 PM
"No signal" or "no satellite signal"?
Message posted on 06 Jan 2025 12:08 AM
Having the same issue all day. Sky Sports Live not working, channels not loading.
