4
This discussion topic has been answered Discussion topic: MR006 error
This message was authored by: Phil167
MR006 error
Sky Q box has recently been exchanged due to a fault, have installed the replacement box, but none of the mini boxes will work, each having the same error "Your Sky Q Mini box has not been able to connect to the activation server". I have completely shutdown, unplugged the router, Sky Q main box and mini boxes, then restarted the router, followed by the Sky Q box, followed by the mini boxes. I have done this several times without success, any ideas?
Avatar for Phil167
This message was authored by: Phil167 Answer
Re: MR006 error
Yes, the issue has been resolved. I used the online chat and they provided the following instructions which fixed the problem.
On your main Sky Q box, press Home on your Sky Q remote, then select Settings followed by Status.
Highlight Watch on Sky Q Mini box and choose Reactivate, then Confirm.
Once the on-screen messages have disappeared, press Home on your Sky Q remote to switch your box back on.
On your Sky Q Mini box, press Home on your Sky Q remote, then select Settings followed by Status.
Highlight Connection to Sky box and choose Reactivate, then Confirm.
Press Standby on your Sky Q remote, then switch off or unplug your box at the mains.
Check there are no lights on the front of your Sky Mini box and all cables are connected properly and undamaged.
Plug your Sky Q Mini box back in and switch on at the mains.
Wait for the on-screen instructions to disappear, then press Home on your remote.
Re: MR006 error
Hi @Phil167
Try Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Avatar for Phil167
Re: MR006 error
Hi oldfella
Thank you for your reply.
I have just tried resetting closest mini box to the Sky Q box by pressing WPS button on the Sky Q box. It goes through steps one to four, but on the fourth step it fails to connect and comes back with the same MR006 error "Your Sky Q Mini box has not been able to connect to the activation server". Prior to resetting the connection on the mini box I restarted the Sky router and Sky Q box, so it was a fresh start. With regard to my setup, the Sky Q box and mini boxes and Sky router are housed in a server cabinet and are on seperate shelves, one below the other with no more than 6" between each, the Sky Q box being on the top. The Sky Q and mini boxes are connected to a HD Anywhere server via ethernet cables and then onto each room via ethernet cables. This means that the Sky Q,mini boxes and router could not be closer to each other.
This message was authored by: Garethshughes00
Re: MR006 error
I have this same issue.  Did you manage to solve it?
Avatar for Phil167
Re: MR006 error
