59
This discussion topic has been answered Discussion topic: Is snow affecting Sky Q
Re: SNOW
@Timot40 wrote:
 Still never improved on these conditions
Never will - it's intrinsic with dish transmission.
The Q box does have many apps and catch-up that allow you to access most material without a dish.  Some of them allow live channels, such as iPlayer.  Not quite glass/stream but close.
Re: Is snow affecting Sky Q
Yeah maybe just unlucky timing. Apps  should work.
This message was authored by: Trudy21
My sky is back on.
This message was authored by: simon_01
same here...now the snow has stopped.
Must have been blocking the satelite signals in heavy snowfall.
This message was authored by: Jon65
Re: SNOW
Some of us can't get fast enough broadband speeds for live 4k streaming.
Re: SNOW
Unless that changes, or you stick to HD streaming perhaps, you're stuck with a satellite service, then. That is, until the satellites expire at around the end of the decade.
This message was authored by: Dave10101010
Re: SNOW
I had no sky reception via dish and could t even watch recordings from my planner. Rebooted Sky Q box and all now working so even if snow an issue try a reboot.
This message was authored by: Lewyk
Sky satellite signal has gone on sky box.e her i judt have to ac
Satellite signal is down. Bad weather and I just have to accept it. Well I'm not happy because it is a live football match I'm missing
Re: Sky satellite signal has gone on sky box.e her i judt have to ac
@Lewyk
Presumably the bad weather is snow or low cloud cover so your post has been moved into this thread on the subject. Unfortunately there's nothing you or Sky can do about it.
Sky Go?
This message was authored by: White+Britain
I have not had a signal all day. I assume it's the snow.,
This message was authored by: Glynd
I've not had one all day either. I'm in Manchester
This message was authored by: CGrainger
I've not had a satellite signal since turning the TV on at 4pm. Can't see how it's the weather as there is no snow on the dish and there is no wind. Had this problem a few weeks back and an engineer came out and said it was because we had too many recordings! I've only used 18%!
"No signal" or "no satellite signal"?
This message was authored by: Trinny34
Having the same issue all day. Sky Sports Live not working, channels not loading.
Answered - Go to Answer
