This discussion topic has been answered Discussion topic: Is snow affecting Sky Q
Message posted on 05 Jan 2025 07:52 AM - last edited: 05 Jan 2025 07:53 AM
Re: Is snow affecting Sky Q
If you've had snow overnight see the post currently marked as the answer.
Message posted on 05 Jan 2025 07:55 AM
I cant see the current answer. Still snowing. Can get on ipad ok
Message posted on 05 Jan 2025 07:57 AM
I'm in Yorkshire and the 2" snowfall has affected my TV signals, despite not using a dish....Strange.
Message posted on 05 Jan 2025 08:04 AM - last edited: 05 Jan 2025 08:05 AM
Communal systems are fed by a dish although you don't have a personal one.
The dish may be somewhere on the property or even further away
It is quite possible that the Communal dish is affected
Message posted on 05 Jan 2025 08:13 AM
The current answer is post number 2.
Message posted on 05 Jan 2025 08:48 AM
No signal to all channels catch up working
No signal to all channels, news etc. only thing working is catch up. I have done reset still nothing on all channels
Message posted on 05 Jan 2025 08:53 AM
Re: No signal to all channels catch up working
Having the same problem
Message posted on 05 Jan 2025 08:54 AM - last edited: 05 Jan 2025 08:56 AM
No signal or no satellite signal. They are different.
Is there snow on the LNB on the dish? If so see this thread
https://helpforum.sky.com/t5/Sky-Q/Is-snow-affecting-Sky-Q/td-p/4871474
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in this link
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 05 Jan 2025 09:01 AM
Thank you. No sarelite signal. All channels waiting for tv schedule.
yes snow on roof but we are on fibre ?
Message posted on 05 Jan 2025 09:04 AM
No signal
I have no signal
Message posted on 05 Jan 2025 09:07 AM
Even if you get sky through a local fibre connection from a communal dish, you're still using a dish for live TV and subject to weather effects.
Message posted on 05 Jan 2025 09:09 AM - last edited: 05 Jan 2025 09:09 AM
Re: No signal
Is there bad weather/snow between your dish and the orbiting satellite?
Message posted on 05 Jan 2025 09:12 AM
No satellite signal here either. Followed all of the troubleshooting steps, all other services working fine, only signal provided by satellite not working.
Message posted on 05 Jan 2025 09:21 AM
If snow on the dish is the cause you'll just have to wait for it to clear. It's going to be a problem for a lot of people today.
Message posted on 05 Jan 2025 09:29 AM
Me to
Where's you I'm in nottingham
