This discussion topic has been answered Discussion topic: Is snow affecting Sky Q
Message posted on 05 Jan 2025 02:02 AM
I have checked with my neighbours and they are not having problems with weather, was interested to find out if anyone else is?
Message posted on 05 Jan 2025 07:43 AM - last edited: 05 Jan 2025 07:57 AM
@Daniel0210 wrote:
Your signal is likely to be affected if snow lands on the dish, in particular the LNB but should return to normal as soon as the conditions improve. Don't necessarily try to brush it off as accidentally moving the LNB will then necessitate an engineer visit to realign it.
In addition to what @Daniel0210 says cloud cover / thick snow in the direction of the Satellites can also affect the signal which will improve when cloud/snow gets thinner
Message posted on 05 Jan 2025 02:07 AM
Re: Is snow affecting Sky Q
Hi, mine also went down about 1.50am, there are a few people now with no service, hope it's sorted soon!
Message posted on 05 Jan 2025 02:08 AM
Thanks for letting me know. Hope you're back up by the morning too!
Message posted on 05 Jan 2025 04:25 AM
Mine is currently down too, I noticed around 2:30am and is still down now at 4:30am.
Message posted on 05 Jan 2025 05:42 AM
Message posted on 05 Jan 2025 06:47 AM
Satellite signal
Message posted on 05 Jan 2025 06:52 AM
Message posted on 05 Jan 2025 07:00 AM
Mine is also down says no satellite signal
Message posted on 05 Jan 2025 07:22 AM
I have no signal, tried the usual reset. No change
Message posted on 05 Jan 2025 07:24 AM
No signal
hi anyone else experiencing signal issues due to snow
Re: No signal
See my earlier post. Unfortunately this is not unusual in snowy weather.
Message posted on 05 Jan 2025 07:49 AM
I have no satellite signal
Message posted on 05 Jan 2025 07:51 AM
Mines still off been off since about 1am.
Message posted on 05 Jan 2025 07:52 AM
No satellite signal
Have no satellite signal
