Discussion topic: Hi my mini box won’t connect
This message was authored by: Christine+millwar
Hi my mini box won't connect
Re: Hi my mini box won’t connect
Connect to what?
Avatar for Christine+millwar
Level 0 icon
It says there has been a problem finding your skyQ box on the internet
I'll move you post to the Sky Q forum as you have posted on the Sky Plus one 😞
@Christine+millwar Have you tried rebooting your main Q box ie
then when that is up and running again do the same with your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Fraser141
My mini box won't reconnect
Could you help to get me connected
@Fraser141 Have you tried rebooting your main Q box ie
then
rebooting the mini box
as per my post above yours
