22
Discussion topic: Changing Over Router on Mini Box
This message was authored by davebrad1 This message was authored by: davebrad1
I've switched to a new router and easily switched my main Sky Q box over. But with the mini box there doesn't seem to be any way to do this - it just simply keeps resetting to the old router and as such I now have no signal in my second room
This message was authored by oldfella This message was authored by: oldfella Answer
Re: Changing Over Router on Mini Box
@davebrad1 wrote:
Switched to connection by Ethernet which brings up the Sky Home Screen but Technical Fault on the top left
Hi @davebrad1
When all boxes are connected by Ethernet you can then switch off all Q box WiFi.
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Repeat the network reset on any minis in the Mini Home menu with the Ethernet connected. Again do not do any WPS and just wait for it to connect.
Once it is connected go into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
