Discussion topic: I need a hub lead please
This message was authored by: Ninanoo1970
Hi I need a longer hub cable so I can move my sky box where do I get one from
Re: I need a hub lead please
@Ninanoo1970
Sky will not send you one so you will have to order one yourself from somewhere if you have no local stores nearby that you get get this lead from.
Avatar for Ninanoo1970
Yea I thought that will hv to go into curry's . Thanks
Hi @Ninanoo1970   Exactly, what type of cable are you looking for? You will pay 3 times as much at Currys.
It's the purple  hub lead
Is it an ethernet cable? Or one that goes from the router to a phone socket?
