04 Jan 2024 08:09 PM
I've switched to a new router and easily switched my main Sky Q box over. But with the mini box there doesn't seem to be any way to do this - it just simply keeps resetting to the old router and as such I now have no signal in my second room
04 Jan 2024 09:30 PM
@davebrad1 wrote:
Switched to connection by Ethernet which brings up the Sky Home Screen but Technical Fault on the top left
Hi @davebrad1
When all boxes are connected by Ethernet you can then switch off all Q box WiFi.
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Repeat the network reset on any minis in the Mini Home menu with the Ethernet connected. Again do not do any WPS and just wait for it to connect.
Once it is connected go into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
04 Jan 2024 08:13 PM
Hi @davebrad1
Unless you are on Sky Broadband your mini can only connect to the main Q box or a Sky Q booster if using WiFi.
Try a Network Reset on the mini.
04 Jan 2024 08:25 PM
Thnaks - the mini box seems to now be connected to the new wifi router but can't seem to find the Sky Q box
04 Jan 2024 08:45 PM
Did you carry out a Network reset on the mini ? @davebrad1
If so what happened?
Also who is now your Broadband supplier?
04 Jan 2024 08:59 PM
I did and I was able to connect to the new router and this is coming up with a tick on the settings. Have also clicked reactivate mini box on the main Sky Q box. But when I click reactivate it goes to connecting to Sky Q box it ends up saying cannot find Sky Q box. Not sure why the mini box is failing to connect to the main box despite having a strong internet connection
04 Jan 2024 09:03 PM - last edited: 04 Jan 2024 09:03 PM
Who is your Broadband supplier @davebrad1 ?
04 Jan 2024 09:11 PM
I'm with BT but have just set up a Mercusys home mesh - this is what the main box is now connected to and the mini box also is
04 Jan 2024 09:14 PM
Hi @davebrad1
Afraid mini boxes will not connect by WiFi to 3rd party WiFi mesh or 3rd party routers.
you could get some success if you could connect the main Q box and the mini by Ethernet to the mesh units
04 Jan 2024 09:29 PM
Hi @davebrad1
05 Jan 2024 08:47 AM - last edited: 05 Jan 2024 08:49 AM
Posted by a Superuser, not a Sky employee. Find out moreYou'll need to connect the Q by ethernet too if you do that. If it's using the meah wifi to get to the internet it will not try to talk to minis via that but still via its own mesh. I assume your mini and Q are too far apart for this to work.
If you connect the Q to one of your mesh nodes via ethernet that should work too.
05 Jan 2024 10:10 AM
Thanks everybody - especially Oldfella - turning off the wifi prived to be the key. If you were anywhere close to me I'd take you for a pint or drop you off a nice bottle of wine. Thanks again - it's really appreciated
Posted by a Superuser, not a Sky employee. Find out moreYeah if you don't disable the wifi it has a habit of using it on the sly !
05 Jan 2024 10:11 AM
Thanks @oldfella - great knowledge and support
24 Oct 2024 10:22 AM
Hi everyone,
we have just had a new WiFi installed in our house as its old with concrete walls so the sky wifi wasnt able to get around the house and sky were putting these plug in boosters everywhere. I have managed to connect the main sky q box to the new internet but minis won't connect when I do a reset. My problem is the minis are on different levels in the house so not sure how ill be able to connect the minis by Ethernet cable? Sorry I'm not very technical so trying to take this all in and understand it all! Thanks in advance for your help.
