3
This discussion topic has been answered Discussion topic: Broken button on Sky multiroom box
This message was authored by: damon987
The sensor button has broken or been pushed in and now is floating around in the multiroom device.
is there any way of taking it apart or do I need to send it back to get a replacement? @Sky
Re: Broken button on Sky multiroom box
@damon987
Sky will probably arrange a doorstep box swap whereby DPD deliver a replacement and take the faulty/broken mini box away with them. You'll have to have the box unconnected and ready on the day.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
You'll need to contact Sky for a replacement box.
@damon987
Avatar for damon987
Thank you both. Will contact Sky.
Answered - Go to Answer
