32
This discussion topic has been answered Discussion topic: Activate hayu not working
This message was authored by: Tanja1
To activate hayu after subscribed for trial is not working. It  it says not working at the moment on the sky website
Avatar for Tanja1
Level 2 icon
This message was authored by: Tanja1 Answer
Re: Activate hayu not working
@Anniemac1980 @Nandroidia
It took me a while to figure out how to activate hayu.
Click on sign in with hayu not sky
You need an hayu account first
hayu.com/pair
On hayu site scroll down to supply chain
It doesn't say sky partner but you still can type in the number you see on your telly.
Hayu should work after
I hope you get what I mean 😁
This message was authored by: Anniemac1980
Hayu issues
Is anyone else getting a fault when they try and activate Hayu through sky? I follow the QR code that Sky has on screen and then I get a messages saying
Does anyone know what the issue is? I phoned sky on Tuesday and the problem is still occurring. So I am unable to create or link an account because it now thinks I've subscribed. Help, I need my fix of mindless American reality! 🤣🤣🤣
Avatar for Tanja1
Level 2 icon
Re: Hayu issues
@Anniemac1980
I can't active hayu too. That's what it says on the sky website.
@Tanja1 sky sort of said it's not an issue even though the lady on the phone had the same issue. It's frustrating isn't it
It's so frustrating
Avatar for Tanja1
Level 2 icon
@Anniemac1980
Embarrassing for sky and annoying for us. No way I pay £4.99 after the 3 months.
I checked with Sky yesterday and apparently we'll only get charged if we managed to get an account set up, otherwise they can't charge us. I can't say I'm confident about that though!
Avatar for Tanja1
Level 2 icon
@Anniemac1980
Good to know thanks
Avatar for Tanja1
Level 2 icon
@Anniemac1980
Good morning
Hayu is now working after speaking with sky this morning. I hope they can help you as well.
Avatar for Tanja1
Level 2 icon
@Anniemac1980
You need to create a sky ID to link hayu to sky Q.
Sorry I'm  not a master in technical stuff😁
Thank you. I'll try again.
This message was authored by: Nandroidia
I'm getting the same message, Sky sent me a direct link but getting that message still even after signing into my Sky account.  Was told to just keep trying 🤷‍♀️
That's the exact same response I got and it's still not working. I guess sky just aren't really that interested
Avatar for Tanja1
Level 2 icon
hayu.com/pair
Thank you, that's worked. Does yours say somewhere that you are getting 3 months free cos mine just says free trial for 7 days
@Tanja1 @Nandroidia .
Answered - Go to Answer
