18 Jun 2022 08:40 AM
Thanks very much for your efforts here!
Your solution worked for me. I wasn't very hopeful when the username and password fields came up!
I found that either O2 or sky.mobile worked as the network name. There is very little feedback at the crucial moment but patience is the key! Then just backing out of the menus as there is no ok button.
Thanks very much!!
26 Nov 2022 03:16 PM
Stumbled on this string of posts Googling in frustration trying to get Sky SIM to work in 2020 Discovery Sport. It does work and huge thanks to this discussion for solving the problem. Couple of additional pointers if you are as dim with tech as me: I already read that you needed to change the Service Provider to O2 from Sky but I could not find that menu. I found the "Mobile Data" on/off toggle. Eventually I worked out that if you tap on the actual words "Mobile Data" it opens another menu (d'oh!). Change the auto on/off option for service provider to "off" and then boxes appear for you to fill in. Type in O2 and everything will work. Nothing else needed, no username or password etc - leave those blank. Never underestimate an older man's inability to understand tech instructions!!! Thanks again for the help, especially @Benno123d who answered it way back.
05 Jan 2023 07:16 PM
I had the same issue, brand new Sky Sim in my RR Velar and although it showed that there was 4G full signal, I had no Internet connection via the car's hot-spot.
I changed the network setting from Sky to O2 and problem instantly solved.
16 Mar 2023 11:37 AM
I had struggled for over a year ith this on my RR Velar.
JLR changed the sim reader and later the telematics control unit.
Eventually tried a sim from an alternative provider and all worked well.
Came across this thread, turned off the auto select for provider and manually entered 'O2' and bingo all works well.
Very frustrating that both Sky and JLR are not aware of these issues.
Can't thank you enough!
21 May 2023 12:11 PM
Can you tell me which line in the APN settings need changing as my setting is changed tocurrently as below, is this correct as per above solution
Name: Sky Mobile Internet
APN: mobile.sky - changed to O2
Username: None
Password: None
MCC: 234
MNC: 57
APN Type: Default
MMS APN Settings:
Name: Sky Mobile MMS
APN: mms.mobile.sky
Username: None
Password: None
Proxy/MMS Proxy: 185.110.178.97
MMSC/MMSC URL: http://185.110.178.96:38090/was
Port/MMS Port: 9028
MCC: 234
MNC: 57
Authentication: None
MMS APN Type: mms
APN Protocol: IPv4
21 May 2023 06:16 PM
Might have to put o2
23 May 2023 05:55 PM
Latest update.....it now works, and the answer is that i deleted everythin apart from the following
APN: sky.mobile
Username:
Password:
MCC:
MNC:
APN Type:
MMS APN Settings:
Name:
APN:
Username:
Password:
Proxy/MMS Proxy:
MMSC/MMSC URL:
Port/MMS Port:
MCC:
MNC:
Authentication:
MMS APN Type:
APN Protocol:
