07 Apr 2021 02:03 PM
So it's a 67 plate and the 3 year data pack has now expired. I have registered with Cubic Telecom who provide data plans for Audi to the integrated SIM, however, they are expensive compared to me buying a standard Sky SIM and rolling my accumulated data from my mobile contract onto it....
07 Apr 2021 02:05 PM
So if it were me I'd use the sky sim altogether at all times without the data plan from Audi. My method is because I have the Audi data plan until 2022
07 Apr 2021 02:08 PM
Yes ofcourse, if it was new I would be using the integrated SIM.
Perhaps I will order a new Sky SIM and see if it will work in the car. At least then if I can't get it working I can send it back within 14 days.
06 Sep 2021 05:16 PM
Success with Jaguar XJ!
Changing Provider to O2 also worked with 2018 Jaguar XJ. Click on Mobile Data to enter sub menu, change to Manual configuration, change 'Sky' to 'O2'. Leave User Name & Password blank, then click on 'Connect'. It took around 40 seconds for 'Connect' to change from 'greyed out' to black. As soon as 'Connect' was available, 4g came up almost immediately.
06 Sep 2021 06:03 PM
yes it will, you just need to go into setting in your car and inset o2 rather then sky
hope it works
Cheers
David
06 Sep 2021 06:25 PM
Hi guys,
Thanks for your reply.
So once the SIM is in, how do I amend the settings?
Greg
20 Apr 2022 07:05 PM
How do you change the settings in a 2016 range rover as i cant see where to do it
20 Apr 2022 07:23 PM
Not sure but try going into setting, find the carrier of the sim and change it from sky to o2 good luck
14 Jun 2022 04:07 PM
Can anyone help, I have a new sky sim and i want to follow the steps here, but i cannot get the car to recongise that there is a sim in the slot, i have done everything and i am waiting for the sim to fire up, but i get the three dots and then it reverts back to the reading sim and where the 3 dots were it looks like a sim with a line through it. I have activated the sim, and have even tried it out in a spare phone. I also cannot get to the mobile data screen to change the provider to o2.. anyone else had this problem... 2017 Evoque Autobiography...
14 Jun 2022 04:14 PM
yes had the same problem with the same car,
Had to change Sky on the settings to O2 and worked fine after that, but it was so long ago and no longer have the car so can't help anymore I'm afraid.
14 Jun 2022 05:29 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Ralphy1969 did you activate the sim before putting it in the car ?
14 Jun 2022 06:08 PM
@63johnw i did, i activated it though sky and if i put it in a spare mobile it works. I have even tried moving my car to another location to see if it was the signal but no luck.
14 Jun 2022 06:21 PM
Hi it is Definitely the settings in car, not the SIM card, I went though all the same thought process, but when I found the car (in setting) showing 'sky' I then changed it to '02' and hey presto it worked, not sure if it was 02 or o2
14 Jun 2022 06:28 PM
trouble is @Benno123d I cannot get to the settings screen, the car doesnt recognise that there is a sim in there, I put the sim in the slot, I then slide the option on Mobile Data to the on position and there are 3 lines in the opt left corner of the screen start moving, after about 30 seconds the 3 dots change to a sim card with a line through it and then starts again with the 3 dots again, when the 3 dots are in i press the mobile data to go into that screen and change the provider, but that screen never comes up.. I have tried 2 sims in the slot and it happens to both. So potentially could be the car, but i can pair my phone to the entertainment system, so not the end of the world.
14 Jun 2022 06:55 PM
Try your local Landrover dealership, mine were very helpful
