Discussion topic: Sky go wont connect to sky q box
This message was authored by: Bad2
I've tried uninstall the app even restarted the box  but still nothing
Re: Sky go wont connect to sky q box
Is the option to connect to each other turned on via both your Sky Q box and the Sky Go app (in the settings) ?
Avatar for Bad2
Yes they are
Has it been working or is this the first time you have tried to connect them ?
Do you have multiscreen on your TV package ?
Avatar for Bad2
I've tried it before bit it was sometime ago and I do have multiscreen
And the app and your box are on the same Wi-Fi connection ?
Avatar for Bad2
Yes they are
@Bad2
This link explains how this works so you will need to respond to the chat bubble at the bottom of the page when it appears:
When the chat bubble does appear you will need to respond to it as soon as you can.
This isn't a live chat so replies are not instant.
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to @Bad2.
This message was authored by: Mr+Flibbles+86
We are still looking to help you @Bad2 . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
