6
This discussion topic has been answered Discussion topic: Sky go not showing TNT Sport but it’s paid for on my SkyQ
This message was authored by: TomP28
I have moved out of my house to have work done at the property. I have SkyQ at home which includes TNT Sports. I can't access TNT sports on Skygo. Why not?
This message was authored by: Anonymous Answer
Re: Sky go not showing TNT Sport but it’s paid for on my SkyQ
@TomP28 wrote:
TNT through my BT account.
That's your problem then, Sky Go is only usable if you're paying Sky directly as the App doesn't know you have a subscription. Do TNT or BT not have an App you can use?
Do you pay Sky or TNT themselves for access to the channels ?
Avatar for TomP28
As stated above you can only use the Sky Go app is you pay Sky so you will have to use their app instead. Should you change to Skybling you then you can then use the Sky Go app,
This message was authored by: Richardr1
If you get it from BT direct, then you should be able to get it via the Discovery+ app. You will need to check with them, as the login will be different from the free version that you get with Sky subscriptions, and which doesn't include TNT sport.
[Edit - see instructions here - https://community.bt.com/t5/TNT-Sports-on-TV-Online-player/Trouble-activating-discovery-Read-this-fi...  - you will need to be logged on to you BT account to start the process]
I'm a Sky VIP customer, where do I get my Skybling from?
