142
This discussion topic has been answered Discussion topic: Sky Go technical and access restricted error
Avatar for mdsj144
This message was authored by: mdsj144
Re: Sky Go technical and access restricted error
This has been going on since october obviously something changed at skys end would it not be worthj while reverting what ever they did to put the old version that worked back on
This message was authored by: pfmk
It's obvious it's an account issue, but the 1st line support are so bad, it's had to be escalated to the Executive Team to be resolved.
This message was authored by: King+of+no+man
Re: SkyGO wont work
I have the exact same problem. Sky have forwarded me this thread to see was there anything useful on it to help.
have you found a solution?
Re: SkyGO wont work
It suddenly started working.
No explanation,  no apology, no contact.
Avatar for mdsj144
Re: SkyGO wont work
Ill try mine tonight see if it has mysteriously started working
This message was authored by: Ant72
Sky go won’t login in iphone
I cannot login to sky go, tried all sorts. Keep getting an error message. Any ideas?
Re: Sky go won’t login in iphone
@Ant72
What is the error message ?
It's always comes up with '
Because of a technical issue, you cannot watch this channel. Please try again later.
Then goes back to login screen
@Ant72
Try linking your Sky ID to your account, help on doing this can be found here:
https://www.sky.com/help/articles/sky-id-cant-access-all-my-services
Still not working, not sure how to link accounts with the link doesn't really help. But appreciate you replies
Avatar for mdsj144
So went on last night all is working again nothing changed my end 3months not working now it does looks like sky have done something
This email address is not valid
apps@sky.uk.
This message was authored by: CJ74
For those with this issue, it seems Sky are now (very slowly) rolling out a fix on customer accounts, but they won't tell you they've done it.  So just keep trying Sky Go and fingers crossed....
This message was authored by: Slcmpc
They haven't fixed mine.
I wonder if Google AI picks this up. It says that you have to contact Sky but as many of us know you cannot do that. Google AI should really say, if all else fails give in because Sky won't help you.
Sorted now, rang sky and it was escalated to the technical department. Took some time on the phone and had to have a call back, but eventually got sorted and can now use in my phone and all other devices.
Answered - Go to Answer
