3014
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by Davidr+542 This message was authored by: Davidr+542
Re: Sky Glass outage
What worked for me is to hold the power button the side, wait till the red light starts flashing, then while still holding the power button press the power button on remote.
The TV will reboot and you must follow a few easy steps but it doesn't take long.
I'm now up and running again @Katrina2511
This message was authored by CathSteen This message was authored by: CathSteen
Re: Sky Glass Power up Issues 19-9-24
Sorry @NeilSh genuinely hope you manage to get it working. Shameful that there's is absolutely no comms from sky other than when you go into the app "some sky glass / stream users experiencing issues" considering it seems to be ALL sky glass & stream
This message was authored by Cma This message was authored by: Cma
Re: Re:sky glass and Sky Puck & Sky Glass Power up issues 19-9-24
Mine said that but I did a reboot turn off hold in power button on the side then switch on still holding the power button for about 1 min it then did a download and went into set up just follow the on screen instructions
This message was authored by Supersaf This message was authored by: Supersaf
Re: Sky glass tv won’t turn on red light just keeps flashing
My Sky Glass TV, 55" won't turn on since yesterday (19/09/24) afternoon.
Checked power cable is ok (microphone light next to power button on side of tv lights up).
Remote is ok and replaced with brand new batteries (just in case).
Tried hard reset, holding power button on tv  an switching mains power back on. Red light on TV eventually flashes like mad and then the sky image/logo appears and then an update takes place and then a second update and then nothing. IT just goes black.
Can anyone help or advise please? I got the TV brand new back in August 2023 ( just over 1 year).
This message was authored by Paul6758 This message was authored by: Paul6758
Re: I have a issue with my skyglass
Power cut yesterday when power came back on the tv came on briefly then went off now shows a flashing red light on bottom it's sky glass I've done the usual things ie turned off and on etc any one else having same problem in Stevenage area
This message was authored by Debbie92 This message was authored by: Debbie92
Let me know as mine don't work. Do I wait for sky to sort it as there is an outage in our area
This message was authored by KPhoenix33 This message was authored by: KPhoenix33
Re: Sky Puck & Sky Glass Power up issues 19-9-24
Followed the suggested restart steps, reconnecting the remote, WiFi & Sky account, entered PIn etc. Took a while but Sky Steam is back on!
Hopefully, it is now working. However, I haven't tried switching it off & on again  yet!
This message was authored by Max58 This message was authored by: Max58
Had no luck last night with reset function
Just tried again as mentioned in chat below, followed on screen prompts and now up and running
good luck everyone
This message was authored by Dazzasky This message was authored by: Dazzasky
@Super+Anthony wrote:
I have just been told to leave it plugged on and wait for the fix and update to come though. I am stuck on the loop with flashing white on the puck and then turning off and on and seeing the Sky logo on and off on the TV.
Why don't you try the recovery procedure as posted by Sky. I followed it and now all my pucks are working. @Super+Anthony
This message was authored by Van24 This message was authored by: Van24
Re: When will you fix the sky glass turning on problem.
I have had no tv since I got home at teatime yesterday, so frustrating 😶🌫
This message was authored by Shakazulu This message was authored by: Shakazulu
Re: No standby light on, on sky glass
I have change plus turn off multiple times still don't work no stand by light you can't even speak to a real person at Sky I am so upset I did have same problems remote wouldn't tune TV on even though I have the red light now no light no power at all.
This message was authored by Denise555 This message was authored by: Denise555
Now it won't let me activate says error
This message was authored by Paul471 This message was authored by: Paul471
My sky glass tv is still not working,  have done the reboot etc. and nothing.  Does anybody know how long it is going to take to get the issue sorted? Thanks
This message was authored by Tammy28 This message was authored by: Tammy28
@JPCQ Im 44 minutes into the call with a 'sky expert'. Im looking forward to this conversation
This message was authored by 56Bev56 This message was authored by: 56Bev56
Re:@Laura240 Sky glass tv won’t turn on just flashing red light
Hi Laura. Which of the 2 buttons do I press firstly ?
