Discussion topic: Sky Glass tv asking me to pair the remote and won't connect to my router
Message posted on 21 Sep 2024 11:58 AM
My Sky Glass tv is requesting that I press 7 and 9 on the remote for 3 seconds. After doing that and selecting continue, it's giving me 3 options to connect to my router.
1. Using WPS button on router
2. Using password
3. Using a wired connection
Option 3 is bot really an option for me. Option 1 accepts the password, but doesn't connect. Option 2 does absolutely nothing.
Message posted on 21 Sep 2024 04:52 PM - last edited: 21 Sep 2024 04:53 PM
Re: Sky Glass tv asking me to pair the remote and won't connect to my router
@DavidPet The following should happen if you select option 2 using password. You will be presented with a list of networks within range of your Glass. Select the network that is yours and then input your network/router password. It should then verify the details and move on to the next part of the setup procedure.
