21 Sep 2024 11:42 AM
Already done the recovery multiple times and it's still not working. Sky are just pasting the same answers to everyone and won't give anyone any more info.
Sky puck up and working again, after complete restart, this time we had all the flashing lights
@Jporch316 wrote:
@Sy70 wrote:Mine is doing this too! So frustrating 😫
Hi
are you able to follow the step by step recovery process on page 2 of this rather large thread
Yes it completes the download then just freezes on the network setup page
21 Sep 2024 11:43 AM
Mine too, and sky are being no help just copy and pasting their restart help page.
I have the same issue.. I thought my sky remote was faulty but seems like we have a problem in the area. My 3 year old is doing my head in with no TV or YouTube.
21 Sep 2024 11:44 AM
@Sy70 wrote:
Hi
Are you able to use an ethernet cable temporarily
also can you try rebooting your router
also try holding the remote really close to the device as it defaults to infa red connection and doesn't work from to far away
21 Sep 2024 11:47 AM
I'm starting to lose my mind. Since yesterday, My sons Sky Glass no longer connects to WiFi via password or wps. I have to lug it downstairs and hook it up to a wired connection. Get everything working. Get the WiFi connection working.
take it back upstairs and plug it in. It works!
overnight it turned itself on and went to network setup screen like it's reset itself again.
took it all downstairs, did everything again. Bring it back up and plug it back in and it goes into setup mode again with the blue screen. Can't connect again.
im going bonkers.
21 Sep 2024 11:48 AM
Thank you very much, all back working 👍 Good luck all.
Yea I did that reset while on phone over an hour with sky yesterday and yet hit another fault where ur won't accept pin. The sky guy said its another fault to wait to fix.???
It took ages tryjng to get box turned on after it flashing on snd off SKY on My tv then No signal etc for a while day and a half and yet now cannot watch anything as can't get it to accept pin.
21 Sep 2024 11:49 AM
Exactly the same situation for me. Phoned sky again today who said there is now a fix but you have to talk to their technical team. Now been on hold for an hour and a half.
Hi
im exactly the same with a useless code on my screen nowhere to put it and nobody answering the phone at sky to advise on an update or info 🤬🤬
not third world I appreciate that but just so annoying in this day & age
21 Sep 2024 11:50 AM
@Chrismurr80 wrote:I'm starting to lose my mind. Since yesterday, My sons Sky Glass no longer connects to WiFi via password or wps. I have to lug it downstairs and hook it up to a wired connection. Get everything working. Get the WiFi connection working.
im going bonkers.
That's a new one ! Maybe leave the tv plugged in downstairs for a few hours after setting it up then power it off a few times at the plug while downstairs to let it do some background stuff
21 Sep 2024 11:51 AM
My sky puck won't turn on anyone else having the same issue been on hold to sky for almost an hour
If you are having problems at network set up page try pressing the wps button on the router till it flashes and chose that in the options for connecting to the network.
21 Sep 2024 11:53 AM
Exactly the same with us still doing Exactly the same over and over ..
