3833
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by Mellissa7714 This message was authored by: Mellissa7714
Skyglass
Hi, anyone in the Broxburn/uphall area having issues with there sky glass or work for sky ? I know they are having issues at the moment I have managed to get my tv on by resetting it as was stuck on standby but now my tv will not connect back to my ee wifi.
I have waited a total of 2 hours and still can not get through to anyone at sky as usual.
Can anyone help Thanks
This message was authored by Yelselh This message was authored by: Yelselh
Sky Stream TV still not working
Sky Stream has been out for 2 days now. Whats going on!?
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Re: Sky Stream TV still not working
Have you followed the steps here: https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on ?
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
GD1
@Yelselh  If you have not already done so have a look at the Answer (post 2) and follow this link https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on for the recovery process. It has not worked for all subscribers
Most people who have an issue seem to get stuck at either the PIN or activation steps. If asked for a PIN just ignore it and unplug your Glass TV and then plug it back in again after about 30 seconds. After it reboots you should be able to continue the recovery procedure.
When you are aske to enter an activation cove ensure you are logged into your My Sky account or you will get an Oops..... error message.
This message was authored by Jporch316 This message was authored by: Jporch316
Re: Skyglass
 Antony connect with an Ethernet cable temporarily to get you up and running ?
also you may want to pull the plug on your router for 10 mins
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
This message was authored by HuwJames This message was authored by: HuwJames
My Sky glass tv has not been working since Friday.
My Sky glass tv has not been working since Friday.  I have tried the suggestion online to hold the reset button whilst turning the power on.  But that doesn't work either.  Seen on the BBC website that this is a national problem not just me!  Tried calling the Sky helpline Friday, Saturday and today but give up after an hour each time.  Useless service from Sky.  No help no nothing!  Can't even play DVDs' on the tv.
Will be going back to conventional tv after this and cancelling my Sky tv.  Lousy service!  Not impressed!
Re: Sky Glass Power up Issues 19-9-24
Hi, I have tried that multiple times nothing works.
This message was authored by lettice This message was authored by: lettice
@BobW2 wrote:
I would like to add my thanks to  the non Sky employee Superusers giving advice here,  appreciate the time and effort they are giving trying to  help  people.
Thank you.
We as Superusers and customers like yourselves, do appreciate kind comments like this.
Sky Community Superuser. What is a Superuser? Click here to find out
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by Aslamshaikh58 This message was authored by: Aslamshaikh58
Re: Where to put activation code for sky stream
Where I link my account and enter my code
This message was authored by dzy82f This message was authored by: dzy82f
@lettice
Many thanks
This message was authored by Hobbayne64 This message was authored by: Hobbayne64
Can anyone tell me if the sky puck in the bedroom connects to the router via the sky glass tv in the lounge? or directly to the router? My glass is hard wired via a cable to the router, but the puck does not see my router on the available list of networks.
Direct to the router
This message was authored by SKY1992bf This message was authored by: SKY1992bf
@Hobbayne64 all devices are independent and connect separately to router
Please note: I am just a sky customer not a employee - posts from sky employees are clearly marked as such
This message was authored by Logiem This message was authored by: Logiem
We've had to connect the broadband with Ethernet cable. Update software. Then take out Ethernet canle. Then it should accept wifi password.
however, we did this yesterday and we've had to do it again to watch tv today
For your wifi issue.
Can you unplug your Sky Glass TV or Sky Stream puck.
Restart your broadband router
Then try the reset procedure again.
Tipton be certain.
Are you connecting your Sky Glass Tv or Sky Stream Puck via wifi?
If so, if you have one, try connecting an ethernet cable from your Glass Tv or Sky Stream puck to your  broadband router and then try the reset procedure again.
Then once back and running you can redo your wifi in the Glass TV or Sky Stream puck settings with a network reset and remove the ethernet cable.
If you are already using an ethernet cable.
Unplug the Sky Glass TV or Sky Stream puck and while unplugged, remove the Ethernet cable and then reinsert the ethernet cable.
Then do the reset procedure again.
