22 Sep 2024 11:50 AM
@BobW2 wrote:I would like to add my thanks to the non Sky employee Superusers giving advice here, appreciate the time and effort they are giving trying to help people.
Thank you.
We as Superusers and customers like yourselves, do appreciate kind comments like this.
22 Sep 2024 11:54 AM
Where I link my account and enter my code
Many thanks
22 Sep 2024 11:56 AM
Can anyone tell me if the sky puck in the bedroom connects to the router via the sky glass tv in the lounge? or directly to the router? My glass is hard wired via a cable to the router, but the puck does not see my router on the available list of networks.
22 Sep 2024 11:57 AM
@Hobbayne64 wrote:Can anyone tell me if the sky puck in the bedroom connects to the router via the sky glass tv in the lounge? or directly to the router? My glass is hard wired via a cable to the router, but the puck does not see my router on the available list of networks.
Direct to the router
22 Sep 2024 11:58 AM - last edited: 22 Sep 2024 11:59 AM
@Hobbayne64 all devices are independent and connect separately to router
22 Sep 2024 12:00 PM
We've had to connect the broadband with Ethernet cable. Update software. Then take out Ethernet canle. Then it should accept wifi password.
however, we did this yesterday and we've had to do it again to watch tv today
22 Sep 2024 12:01 PM
@Mellissa7714 wrote:Hi, I have tried that multiple times nothing works.
For your wifi issue.
Can you unplug your Sky Glass TV or Sky Stream puck.
Restart your broadband router
Then try the reset procedure again.
Tipton be certain.
Are you connecting your Sky Glass Tv or Sky Stream Puck via wifi?
If so, if you have one, try connecting an ethernet cable from your Glass Tv or Sky Stream puck to your broadband router and then try the reset procedure again.
Then once back and running you can redo your wifi in the Glass TV or Sky Stream puck settings with a network reset and remove the ethernet cable.
If you are already using an ethernet cable.
Unplug the Sky Glass TV or Sky Stream puck and while unplugged, remove the Ethernet cable and then reinsert the ethernet cable.
Then do the reset procedure again.
22 Sep 2024 12:02 PM
Tried doing the reset option but that does not work either! What's going on Sky? Get your finger out and sort out the issue. Would also be good to get an update from Sky on what the problem is and how they are trying to fix it!
22 Sep 2024 12:03 PM
Hi all i have had no tv since Thursday afternoon have tried every one of the tips on here . I get to the point of "link your stream to an account "then i go online and input the 6 figure cide but get no response, i have tried signing in to my account and tried not signing in have also trued every combination under buttons on remote . Will be ditching sky as soon as possible and defo canceling direct debit. Dave
22 Sep 2024 12:05 PM
22 Sep 2024 12:07 PM
My sky stream been down for 3 days now in Wolverhampton area broadband working ok anyone else having issue. 3 days without a paid service is totally unacceptable
22 Sep 2024 12:08 PM
Also spent hours trying to contact sky customer services can't get through to anyone
22 Sep 2024 12:09 PM
I've tried the reset process multiple times, several options on the thread with absolutley no joy at all.
I'm getting nothing out of the TV.
I do not use the 'PUCK'.
I have tried the vitrual assistant and phoning, both which were absolutley use less and basically told me to do the same thing as whats been mentioned in the thread.
Any other suggestions?
22 Sep 2024 12:11 PM
Posted by a Superuser, not a Sky employee. Find out more@MarkBailey1975 I have merged your post to this existing thread that is discussing the same issue.
If you have not already done so have a look at the Answer (post 2) and follow this link https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on for the recovery process. It has not worked for all subscribers
Most people who have an issue seem to get stuck at either the PIN or activation steps. If asked for a PIN just ignore it and unplug your Glass TV and then plug it back in again after about 30 seconds. After it reboots you should be able to continue the recovery procedure.
When you are aske to enter an activation cove ensure you are logged into your My Sky account or you will get an Oops..... error message.
