4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by Flintbox This message was authored by: Flintbox
Re: Sky Glass Power up Issues 19-9-24
@GD1it does not work for everyone and when you ring on phone for hours to be told we are working on it.
This message was authored by Kaz9682 This message was authored by: Kaz9682
@Spilly88 sadly that hasn't worked for me!pressed it for over 5 minutes..just went back to black screen and no signal 😒
This message was authored by BobW2 This message was authored by: BobW2
I would like to add my thanks to  the non Sky employee Superusers giving advice here,  appreciate the time and effort they are giving trying to  help  people.
This message was authored by Gemma411 This message was authored by: Gemma411
Re: Hi my sky puck hasn’t worked for 3 days I’ve tried everything suggested any ideas ?
I have tried the rest button but nothing comes up on my tv screen at all I've tried it constantly for 3 days now
This message was authored by lettice This message was authored by: lettice
Re: Sky Stream Puck stuck on PIN reset
@Mrs+Kennedy wrote:
My pin incorrect if been trying for two days thought I'd sorted it after resetting the puck everything fine then I get to the pin back to 0-3 goes try changing pin do as instructions says and then incorrect geez nightmare
When at the pin stage and it fails.
Remove the power from your Puck or Sky Glass TV,  leave off for a few minutes and repower.
It will continue, follow the instructions.
This has worked for many having a pin issue
This message was authored by Jporch316 This message was authored by: Jporch316
You need to pull the plug then hold the reset button in continually while you put the plug back in and continue to hold until the lights on the front of the puck flash multicoloured (after flashing white ) then leave the button go
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
This message was authored by Law1987 This message was authored by: Law1987
Thanks least I can watch football now and my boys can
GD1
@Gemma411   If you have not already done so have a look at the Answer (post 2) and follow this link https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on for the recovery process. It has not worked for all subscribers
Most people who have an issue seem to get stuck at either the PIN or activation steps. If asked for a PIN just ignore it and unplug your Glass TV and then plug it back in again after about 30 seconds. After it reboots you should be able to continue the recovery procedure.
When you are aske to enter an activation cove ensure you are logged into your My Sky account or you will get an Oops..... error message.
Thanks @BobW2  we can't fix every issue and are learning more solutions as the days go by !
This message was authored by Havill This message was authored by: Havill
I'm starting to get fed up with it all if they don't give answers in which it would be nice if they picked the phone up
to Let us know when Sky will be up and running again
no one is getting a proper service for three days no one is saying anything if it continues, I shall cancel my contract not giving customer satisfaction poor service
GD1
@Havill Have you tried the steps posted in the thread?
This message was authored by Brian225 This message was authored by: Brian225
Yes, service not fit for purpose.....
This message was authored by MacGolfer This message was authored by: MacGolfer
"When you are aske to enter an activation cove ensure you are logged into your My Sky account or you will get an Oops..... error message."
I am logged in.  Same error message.
We really need a clear message from sky on when this will be fixed.
This message was authored by DjIce1983 This message was authored by: DjIce1983
Morning. I got a little closer today on my glass. I managed to go to the network choose your WiFi section. And when entering my password it won't accept it. After 3 attempts of this the Glass Tv crashed and turned off now. What the hell. Still awaiting my call back from 3 days ago
This message was authored by paulb2024 This message was authored by: paulb2024
Hi,
My Sky glass is still not working. It has been like this for 4 days now. When are you going to get this so called outage issue resolved.
A complete lack of customer service as usual from Sky. Will be cancelling my subscription when this is resolved....Shambolic
Locked
